Question about Toshiba Satellite M115-S1061 Notebook
M115 shuts down after couple of minutes
Green LED, orange LED, orange battery LED they all turn off.
I can hear ticking sound from area around the DC power jack.
Do you think that there is something wrong with the motherboard?
Thank you,
Peter
  • 40 Answers
Peter, i think u need to check your power saver settings. It might be set to 15 minutes or less. If settings are correct, then try to update BIOS. Pls visit support.toshiba.com for US model or toshiba.ca/support for Canadian model to look for the updated BIOS version.
Try this Peter, i think it will work.
Posted on Sep 17, 2008
Hello there i have an a665-s6085 . when i plug the adpter a sound is heard like ( tic tic tic tic ) and the led indicating that the battery is charging is flipping . if i remove the battery the flipping...
You have been very thorough in your fault finding, gone through everything that I could think of. Not heard of this before though.
A couple of possibilities:
Regular ticking, points to a hard drive bearing failing
Also, could be a wire or similar catching against the cpu fan
However, seeing as you investigated these, I suggest this could be related to an electrical short, possibly from the DC port on the motherboard, the flickering light on the charge led would bear this out. Try removing the case again, take it into a dark room and power on, look for small arcing across this area
Jul 27, 2011 | Toshiba Computers & Internet
The screen in black, but I get sound. Just replaced the bulb about 5 months ago. There is a green light that flashes, but not the red light. a couple of seconds after turning on the TV, I could hear...
Outside of the lamp failing, the main exhaust fan on the Left side facing the back of the set is common to fail, the set shuts down. But when this happen it always causes the red led on the front of the set to blink a code. If the green led continues to blink, I would inspect the lamp, if appears to be ok, reinstall it making sure that the inner door latch for the lamp is secure and tight.
When looking at the lamp, pay attention to the the bottom of the lamp stem where the bubble is. If you see a discolored, bulged out area on the bubble, the lamp is bad. I have seen this happen even on new lamps from Sony.
I hope this helps,
Skyassoc
Dec 10, 2010 | Sony KDS-55A2020 55" Television
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Ticking noise underneath the car approximately midway.
The sound you hear is the metal parts of your exhaust system and catalytic converter cooling down.Some cars are louder than others but the sound is perfectly normal.
Mar 01, 2010 | 2006 Toyota Camry
Orange LED indicator on the "Power Ring"
From the sounds of things you have a bad RF Board. This is the board that controls the syncing of your controllers, as well as your ring of light. If there is someone in your area that fixes the RROD they may be able to replace your RF board as well. I'd be happy to do it, but shipping would be almost the same cost as the repair. Contact me at Jordan@jordanselectronics.com for more info.
Jan 09, 2010 | Microsoft Xbox 360 Console
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
My ds is automatically shutting down..
put the charger in and then turn it on
Jun 19, 2009 | Nintendo DS Lite Console
Kawasaki Vulcan 1500 (not FI) funky sound after shut down
Hi, Yes it is an electric fuel pump and the ticking is the pump working. So if you hear the ticking your pump should be OK. After turning off the petcock and running the carbs dry the next time you turn it back on you should leave the kill switch on and turn the key on and wait till the ticking stops, turn the key off and back on and wait for the ticking to stop again. You should do this a couple of times to make sure the system fills. Normally you should always use your kill switch to turn off your engine. Also under normal conditions you will not hear the ticking as it only ticks a couple of times to fill the system once it is full. Good Luck to you, This should Fixya!
Mar 24, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
TV making ticking sound when turned on
most times I hear that ticking its the high voltage failure ...most likely a shorted HOT fallowed by flyback. the ticking is your shut-down engaged.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
Toshiba satellite A60 no boot
We can only assume that because the cd drive operates then the motherboard is operating in part, although, the southbridge chip may be damaged, as the northbridge works memory etc. Maybe it is that the processor is fried as there is no fan and the system then shuts down. Toshiba are probably half way there with the answer, unless; they investigated further and decided it was not the processor but the motherboard.
Jan 02, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite M115-S1061 Notebook Logo
272 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
