Question about RCA F27442 27" TV
RCA F27665 27
TV sound works fine. TV guide works and remote works fine also. There is no picture.
  • 2 more comments
  • Anonymous Feb 24, 2008
    I have an rca tv tube type. there is a beeping noise coming from the inside. Will not turn on by remote or manual.
    Is it toast?
    These numbers are on the back tube type A80AEJ15X09
    Serial # D-WBG3P025
    G03KJ526 this may be product # ...not sure
  • Ousmane Traore Mar 01, 2008
    i have a sony commander RM-V202 and i dont have the code for rca
  • Anonymous Mar 07, 2008
    the tamper proof is on how do you take it off
  • Anonymous Mar 27, 2014
    the remote works fine can change channels and sound but no picture at all and please tell me why and how to fix this
A cold solder joint was the problem. No high Voltage. Heated solder joints around the horizontal output.
Posted on Sep 24, 2007
  • 513 Answers
If still under warranty or if you have no electronic repair experience take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. If the TV fell recently the following might apply to you: 1. Cracked circuit board very possible, try changing it. There is a very good chance that the circuit board has some broken traces. You would not be able to see this by eye unless this was very bad. The way to find this, is to troubleshoot the set on the bench to determine which stages are not working correctly, and pursue from there to find where the signal paths, or missing voltages are sourced from. If the set fell, there is also a good chance that the CRT is damaged inside. These tubes are extremely sensitive to being hit or jarred abruptly. I have seen a TV set banged against the side of a door frame while being moved, thus causing damage to the shadowmask of the tube. 2. Check for A/V input circuit board not seated all the way. If this board comes loose, your video will disappear. In case no violence disturbed you set: 1. It is very possible that something is changed in the user setup that is causing the no useable input condition. Check the owners manual and verify the proper user settings, especially the Tv-Guide settings for use with or without cable box or vcr if tv has that feature. 2. this is a fix for a similar set, might apply to yours: Try resoldering all 3 legs of q2300 the if amp transistor and usually pins 1-8 of u2300 the IF ic. This usually takes awhile because there are sometimes a lot of poor joints in that area of the board, look it over very carefully it usually fixes these sets. Good luck, and please try not to take any chances
Posted on Jan 29, 2006
Turn off guide plus rca f19426 no remote
You must have its remote control to make this function OFF
Sep 01, 2012 | RCA F19426 19" TV
I have an L37HDTV10A that i just replaced the main board...i get picture but no sound...everything looks connected inside...also, what remote do i need?...will a universal work?
Go into ur tv Menu goto OPTION go down to Output Select,press enter make sure selection on (Fixed).This fixed selection will pick for the tv out put to tv speaker.Tv should have sound now on it speakers.Try website like Remotes.com to buy the tv original remote work for the best used for to reajustment setting and setting on the tv Menu.
Jul 29, 2011 | Vizio L37 Television
I have an RCA L40HD33 model .... Tv has picture but no sound... the dvd player works fine both picture and sound.....Help??
i have lhd4033d rca tv dvd combo. was having sensor problems with my remote. bought a new one. still not working. took front screen off to find out that I had two wires broken. now the problem is solved. tv works fine.
Mar 13, 2011 | RCA L40HD33D 40 in. LCD HDTV
No TV lineup
Ask here, they can get remote codes and manuals for every RCA remote and TV. Send them both model numbers.
Aug 02, 2009 | Panasonic Televison & Video
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA Guide plus gold gemstar T.V
I have a guide plus gold gemstar tv and I cant program my direct tv remote or Innovage jumbo remote to operate the tv, can anyone help?
Oct 22, 2007 | RCA F32450 32" TV
No Picture on TV
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
   Sorry to ask so many  ?????   Let me know how it goes!!  T.
Oct 17, 2007 | Televison & Video
RCA F27442 27" TV Logo
208 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
