Question about Kenwood Excelon KAC-X811D Car Audio Amplifier
Error code the error code on my display is flashing E 03 what does that mean?? i am running two kenwood 8X11D.
    Problem Solver:
  • 14 Answers
This error msg appears when the speaker cord is shorted When the speaker output is in contact with the vehicle ground
Posted on Jan 29, 2006
SOURCE:
Model EIDW6305GSI error code 03 comes on after about an hour after cycle starts could anybody tell me why this happens thanks
Good Morning steven hutchings, thanks for your inquiry!
I understand that your Electrolux dishwasher is displaying an error code 03. Normally, error code 03 means an issue with the wash motor, wash motor hall sensor, or control panel. I would suggest performing a reset on your dishwasher that could help clear any false error codes. You can reset your dishwasher by flipping the household circuit breaker in the off position for ten minutes. If you continue to have an issue with your dishwasher displaying an error code 03, I would recommend having a professional technician come out and properly diagnosis your dishwasher. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Dec 04, 2014 | Electrolux Dishwashers
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
My red light is blinking and the screen says E-03 and i am not sure what it means
Red lights and error codes usually mean a fault ha occurred. Usually blown output transistors or input power supply caps are to blame. Don't try to fix unless you are comfortable with doing that and have the equipment. Also try emailing Kenwood tech support, they will be happy to tell you exactly what the error code is and possibly why it is happening.
Dec 04, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Blinking E-03
somthing is fried on your motherboard
Apr 28, 2009 | Kenwood Excelon KAC-X811D Car Audio...
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Protection Function flashing with error code E-2
I do believe that error is a short between the positive and negative terminals. Check your wiring and measure with with a ohm meter, it should be more that 1, if not 2 ohms. With the wires from the speaker termanils removed and the amp off check the condinuity between the two terminals, there should be none...if you have some that thats where the short is occuring and work needs to be done on the amp to fix the problem
Dec 15, 2006 | Kenwood XXV-03A Mono 25th Anniversary...
Amp reading E-03
the manual say it means that the speaker cord is shorted, or when the speaker output is in contact with the vehicle ground, i hope you can solve the problem with the info i just gave. good luck
Oct 04, 2006 | Kenwood Excelon KAC-X811D Car Audio...
Kenwood Excelon KAC-X811D Car Audio Amplifier Logo
687 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
