Question about Sub-Zero Refrigerators
I have a sub zero side by side fridge. Noticed that the moulding on the freezer side door was warm and the white gasket the seals both doors were very warm to the touch. Took vent plate off the houses controls off vacumned out any dust and what we believe to be the condensor which would be in the front of the freezer side seems to maybe be the culprit. tapped on it and it came on. Is it suppose to run all the time or go on and off and does that seem to be a problem with these refrigerators? Could it be the condensor itself or maybe just a faulty switch?
  • 958 Answers
The condenser fan should come on the same time as the compressor.
the compressor run on and off as fridge reaches set temp.
so as the fan, but if the fan can not start by itself, it may just need a good lubrication.
tnx 4 using fixya,
drcool.
Posted on Sep 07, 2008
My sub zero has condensation forming inside the refrigerator
Hi - Did you take the vegetable drawers out to see if there is ice in back? If so, you might have a problem with the refrigerator seal. Defrost the ice and then check the seal of the fridge! If you don't have ice behind the drawers, still check to see if the seal is good. When you close the fridge door, it should be very hard to open if you try to re-open it quickly.
Jun 28, 2014 | Sub-Zero 650 / O Bottom Freezer...
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero - 700 TCI 2 :Water is forming on bottom of Frig.
Most refrigerator doors are adjustable. You may find that adjusting the door so that there is a proper seal eliminates the water collection problem
Sep 12, 2012 | Sub-Zero 700TC Bottom Freezer Refrigerator
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
May 21, 2009 | Refrigerators
Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Mar 27, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Seals are hot
hI iF YOUR FRIDGE AND FREEZER ARE COLD AND TEMP IS OK THEN ITS FINE oN FRIDGES THERESHEATERS THATGO AROUND THE DOOR TO KEEP THE CABINET WARM TO STOP CONDENTION SO THIS IS NORMAL THANKS FOR THE QUESTION THE APPLIANCE DOC
Sep 12, 2008 | Sub-Zero 632 / S
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Sub-zero Refrigerator Door
song to me door gasket was not properly installed, We using electric steamers to make rubber softer and good sticking. Right after door seal was replaced. Also, it could be that: a bottom door hinge parts broken /little white plastic cams damaged/,or, fridge not leveled or too heavy load on door shelfs.
________________________________________________
http://www.subzerolosangeles.com
Jun 27, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerators Logo
143 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
