Question about EPoX EP-8K9A Motherboard
HURRAH! Used a PS2 keyboard, booted from disk and installed XP... however... we have a 120GB harddrive in there but on c:\ it's only showing 57gb.... I thought it was weird when it was doing the partioning thing when it was setting up xp... it did say that but it did recognise a total of 120gb... how can I make the rest available? Also, I can't get on the internet... I thought it was only a matter of pluggin in the rj45 and then thats it... but perhaps not... the cable modem is connected to the netgear router and the computers are connected via cable.... thought it'd be simple... but apparently not... please can you help?
    Scholar:
  • 187 Answers
With regards to the space issue, check what is showing in Computer Management > Storage > Disk Management. This is available via the Administrator tools (either in the control panel, or if you've enabled it, on the start menu). In DM, you should see "Disk 0", this is your primary drive. Aslong as the drive shows the full 120GB, there's not a problem. If however, it's only showing part of it, you can expand it to the full size from the disk manager. With regards to the internet issue, is the machine detecting the network card? If so, is it being assigned an IP address? If it's not showing the card under "Network Connections" (Control Panel), then you'll need to obtain the drivers for the card before you can use it. If the drivers are there, you'll need to ensure it's being assigned an IP address, or has one statically assigned.
Posted on Sep 07, 2008
Asus a8n-e m/b gets power, will not post
Hello from here you can download a manual and drivers:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NE/#download
My guees is that the windows disk is damaged or burned to fast.
Since you not get any picture on screen now the graphic card. maybe malfunctioning try to change that and see what happens.
A ps2 keyboard and mouse must be used.
Because the usb function will not work until the system is fully installed.
A restore disk does not contains a full windows its only for repair
purpose.
Good luck
Nov 02, 2012 | ASUS A8N-E Motherboard
Problem booting into xp home edition on laptop!
Hi Andrew,
Before you install XP check the memory, harddrive, cddrive is getting detected in CMOS or not. What about the data in your harddrive?
connect the harddrive to another PC and copy the Data from the drive. If not you will lose all the data on the harddisk if you install the XP on the same disk.
If you had mentioned the system configuration, i would have told whether you can install XP or Not. Since its a laptop and just 5 years old i guess you can install XP on that.
Raj
Jan 13, 2010 | Computers & Internet
My internal touchpad is frozen, and an extrenal mouse does not seem to work. Is the solution to use the Acer recovery disk, and how do I get the computer to boot from the disk?
try to use a PS2 mouse, it goes into the PS2 slot behind the notebook, the PS2 slot can be used for both (either) mouse or external keyboard
to boot from the disk u need to change BIOS settings...
i will give u full details of how to change BIOS setting if u r keen on that and if ur PS2 mouse dont work either...reply me
Dec 17, 2009 | Acer Aspire 3680 Laptop
I need to reformat a dead harddrive
Hi there !!
Method 1: Perform a clean install of Windows XP loadTOCNode(2, 'resolution'); A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk in Windows XP To perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Here's the link that contains the screen shots as well:
http://www.buildeasypc.com/sw/windows_xp.htm
Try these steps & hopefully you will be able to format the Harddrive.
Regard's
Anurag Shukla
Sep 03, 2009 | Microsoft Windows XP Professional With...
System recovery disk used and not key board does not work
For that matter, when reinstalling your windows xp, you have to Delete the partition and format it. Sometimes when your system has viruses and if you just recover or repairing it using your OS installer won't work out because it cannot delete the virus. So you really have to delete the partition and reformat it again. When done, install updated full version antiviruses like avg 8 or avast. They really protect your computer.
Best regards
Dec 26, 2008 | HP Pavilion ze2000 Notebook
Swaping hdd
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Oct 31, 2008 | Dell OptiPlex GX110 PC Desktop
Verbatim 120GB external hard drive
goto Control Panel, administrative tools, Computer Management, Disk Management, If it pops up a new disk install wizard follow the directions in it. If not then find the new disk that has no partition on it, right click on that drive to create a partition, then right click on the drive to format it, if it hasent done so already.
Mar 16, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Harddrive
Get into boot setup and change the 1st boot device as hard disk
Dec 30, 2007 | Computers & Internet
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Down load the ps2 game in hard disk
When you installing PS2 HardDrive with Network adapter you'll need HD Loader Disc (you can find it with a bit of googling) to execute game although elf applications from the harddrive. but if the laser lens of your ps2 can't reading a disc you will need installing a modchips such as infinity. Modchip like this will launching BOOT.elf on memory card during boot of PS2. see here http://e-arena.blogspot.com/2007/04/boot-up-ps2-hdd-via-memory-card.html
for giude. hopefully this helps.
Nov 05, 2007 | Sony PlayStation 2 (PS2) Console
EPoX EP-8K9A Motherboard Logo
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
