Panasonic NN-T888S 850 Watts Convection / Microwave Oven
Problem for Panasonic NN-T888S 850 Watts Convection / Microwave Oven
Tappan Microwave Oven
By Ifixmax on Sep 07, 2008
This oven went dead.No lights on the interior or LCD panel.It's about 15 years old.
Solution #1
posted on Aug 11, 2009
Not Rated)
lahayes575
Rank: Apprentice
Rating: 0%, 0 votes
Panasonic Genius NE-691, how do you replace the light bulb?
Was this helpful?
Yes
No
Solution #2
posted on Sep 16, 2008
Not Rated)
MicrowaveSvc
Rank: Guru  Panasonic Kitchen Appliances  Expert
Rating: 89%, 5021 votes
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find an authorized Panasonic servicer here. You can order Panasonic parts here.
Was this helpful?
Yes
No
Popular Solutions for Panasonic NN-T888S 850 Watts
Questions and Unsolved Problems for Panasonic NN-T888S 850 Watts
Do you recommend Panasonic NN-T888S 850 Watts Convection / Microwave Oven?
Answer
Answer
The turn table on my Panasonic NN-ST477 works sometimes but not others is there anything I can do to... (More)
Answer
Unit stopped working completely. Not even the clock. I found a 15amp 125v fuse inside the cabinet... (More)
Answer
The switch in the door to lock it has broken inside the door. It is about 14 years old is it worth... (More)
Answer
The electricity went off last night during a storm and now the Microwave is on Demo. How do I turn... (More)
Answer
Will not start, H97 appears when I press start, nothing happens.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Ovens Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
