Question about Zio Corporation CameraMate RealTime (cm-50000) Video Capture
Pal capture format
I cant seem to set my cameramate to the correct settings for pal dvds. it continously says "Capture format doesn't match for PAL DVD and will be scaled to fit!". please help!
  • 513 Answers
News, read the following recently: "This is an OK message. This means the video you are capturing is not 720x480, and will be scaled up to 720x480. Video from a camcorder or VCR is not 720x480 and will be adjusted to that resolution. this has nothing to do with your Pal settings."
Posted on Feb 01, 2006
  • 513 Answers
Out of page 26 in the manual: "When you select "preferences" from the list the following window appears on the screen. it offers some general settings for working with ProPix EVE. the check boxes under video standard enable you to specify whether the project is edited in PAL or NTSC." also from the manual page 30 - go to the drop down menu video device, clicking the button on the right gets you into the video input settings dialog box where you can configure the capture device. under the "video standard" pull down menu you can choose PAL. hope this helps, and check back soon because the manual should soon be online on this site. Good luck!
Posted on Jan 29, 2006
I have pinnacle dvd recorder, in step 1 i dont have the option to select dazzle dvd i only have pinnacle file capture therefore i cant get my vhs to transferr
Hi lloyd_kin466
I'm not familiar with Pinnacle stuff but in any capture software , you need to customize the capture options . Set the system to PAL or to NTSC , select the entry . If you are reading from a VHS device , select " composite " and not TV ... etc ... It should work unless your software hasn't been correctly installed or is not compatible with your OS .
Best regards ,
fanaudi .
Aug 31, 2011 | Pinnacle Dazzle DVD Recorder
Connecting Virginmedia TV settop box to PC using Philips TV capture card. Result - sound and picture BUT black & white!!
You are either running NTSC into a Pal system or the other way around. Check the setup menu on the Virginmedia box to make sure what it's running, then make sure the TV card is running in the same format.
Hope that helps =)
Apr 09, 2008 | Computers & Internet
The picture is only black and white and is flashing on my computer screen. Sound is good.
Usually, this indicates that video source is PAL but the capture is set to NTSC, or that the video source is NTSC but the source is PAL.
Make sure that the video capture device is set to match the signal of the input.
PAL is used in Europe, NTSC in North America.
How you set it depends on the Video Capture software you use, but look for PAL/NTSC setting and switch it.
Apr 18, 2011 | Diamond Multimedia ( VC500) Video Capture
When I connect my camera up to the one touch video capture card my diamond media the video camera picture flickers. Can you help me? thanks.
I had the same symptoms - black & white flickering image.
The problem was that my video source was PAL (European) but the software was set to NTSC (USA) video signal format. When I changed this, it was normal colour video without flicker.
I happened to be using AVS video recorder but similar settings probably exist in most capture programs.
Mar 28, 2011 | Diamond Multimedia ( VC500) Video Capture
What is the best HDV1080i 50 settings for finale cut pro 5? My easy setup wont let me log & capture.
It complete depends what you are recording in! PAL or NTSC? and how many frames... FCP is customized to your camera settings, match them up and then capture away!
I capture mine using a PC because then you can play around with both MAC and PC editing platforms as MAC captures are encrypted to only run on MAC.
- Scott
Mar 28, 2011 | Sony HVR-Z1 Mini DV Digital Camcorder
Can I convert PAL?
No, you have to capture a signal in format it is generated, save the recording and then do 'transcoding' into different format. Search web for free transcoding utilities.
Feb 13, 2009 | Canopus ADVC-300 A/D Converter Video...
No colour..
Sounds like you're feeding the ADVC the wrong broadcast format. Either PAL when the ADVC is in NTSC mode, or NTSC when the ADVC is in PAL mode.
Alternatively, your capture software may have a broadcast format setting as well, and that may not be matching what the ADVC is sending out. Remember that the ADVC does not do NTSC<->PAL format conversion, so NTSC analog input becomes NTSC DV, and PAL analog input becomes PAL DV.
Aug 07, 2008 | Canopus ADVC-110 A/D Converter...
No color from VHS on DVD/VHS player
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Apr 29, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
PAL Problem and ADVC110
It's difficult to tell what's really going on by looking at the PC monitor. You should generate a DV file and play it back through the ADVC to a TV and see.
The issue is interlacing. Since the two fields of interlaced video are originated at different points in time, when you play both fields on a non-interlaced display like a PC monitor, you see the two combined and they don't match up. So you get half of a ball before the line, and half of the ball after the line and it looks funny.
Apr 17, 2008 | Canopus ADVC-110 A/D Converter...
Vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Nov 22, 2007 | Canopus ADVC-110 A/D Converter...
Zio Corporation CameraMate RealTime (cm-50000) Video Capture Logo
Top Zio Televison & Video Experts
Jason
Richard Schurman
Richard Schurman
Level 1 Expert
Damen Wong
Damen Wong
Are you a Zio Televison and Video Expert? Answer questions, earn points and help others
