Question about Sony Cyber-shot DSC-W170 Digital Camera
Turn the power off and on again
When I try to take a fully zoomed picture, I am instructed to "turn the power off and on again." This ONLY happens when the zoom is completely engaged. Partially zoomed pics are not a problem.
Thanks in advance
  • 74 Answers
Turn on
gently hold end of lense and twist and pull gently you may hear a click dont force it
turn on and off again and this should solve problem
Posted on Sep 12, 2008
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to www.unitedcamera.com
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
The battery is fully charged. When I turn my camera on, it zooms out, then zooms in, then zooms out, then zooms in, etc. After doing this for about a minute, it finally stops and the screen reads ''Turn...
Try a manual reset...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Feb 09, 2010 | Cameras
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Wont zoom
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
I can't take pictures....
This error message TURN THE POWER OFF AND ON AGAIN is a common error message for digital cameras that has a zoom lens. One possible cause for this is that the battery may had drained out and the lens is still extended. There would be different that steps you could perform and make sure you have fresh or fully charged batteries when performing these steps.
First of course try to do what the error states.
If will not work, set the unit in PLAY mode before turning it ON or immediately right after you press the power. If it successfully gets through the PLAY mode, initialize the settings and restart th camera. You could initialize it by going to the menu and then setup.
If still will not work, turn it off and also remove the battery and allow it to have no power at all for a minute.
If all the steps above will still not work. your camera would require service and try calling its manufacturer to setup a repair on it.
Apr 07, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Not focusing
Do you hear any unusual friction noise while the lens assembly projects out.. if so then the traction assembly of your zoom barrel has developed mechanical obstruction, in which case it has to be serviced. Take it to the service centre and the problem will be solved. If the zoom assembly does not fully extent to its homing position, the camera retracts and lens and powers itself off. Enjoy
Aug 16, 2007 | Olympus FE-230 Digital Camera
Zoom error
I had the same problem with mine and I tried several suggestions, BUT the only one that has worked is to gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur. Another note. I had tried this several times until I finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Dec 09, 2005 | Fuji FinePix E550 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
137 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
