Question about Cyberhome CH-DVR1500 DVD Recorder
No Disc sometimes I get a "no disc" on the machine, but the next day it works fine. When it registers, "no disc", what can I do at that moment?
  • askmikee2 Sep 07, 2008
    Thanks so much for the speedy reply, unbelievable.......How about cleaning?
  • writeaj Dec 04, 2008
    I've sometimes got the 'no disk' message. Then after opening and closing the disk tray the disk loads and plays without any problem. Then maybe a few weeks later I might get the 'no disk' message again. If opening and closing disk tray didn't work, then turning the dvd player off, then on, worked. Player is only 1 year old. I've wondered if maybe it's dust, or just the dvd-reader getting old (worn out).
  • 36 Answers
When the Dvd player cannot read a cd or dvd, it shows the "no disc" message.
The head laser of your Dvd player must be old if you get messages like that, replacement of the head laser may be necessary.
Posted on Sep 07, 2008
  • William VITULLO Sep 07, 2008
    Dusts can cause the laser head to not recognize a cd or a dvd, how old is your player?
    Cleaning the laser head is possible, but you will have to open your dvd player in order to clean it.
    Let me know if you succeed to open your player.
Put in clean commercial disc and get error msg "no disc" period!
Dr. OM,
Lets give it a try. The purchasedate will be 1991 (HI).
I'll suppose you allready cleaned the laserunit.
You can try to clean the laserslides, sometimes they are sticky and dry. Then the laser is not fast and precise enough to read the index of your CD.
Clean them with some alcohol on cottontips.
When they are really clean, use just a little teflonoil to make sure the laserunit slides very smoothly.
Regards,
73's Gerard
May 13, 2010 | Sony CDP-C505 5-Disc CD Changer
Disc wont load afrer working fine all day after short break
This is common with most of the ps2's it is that the ps2 is but takes alot of time so next time don't take any breaks buddy.
Jan 26, 2010 | Sony PlayStation 2 (PS2) Console
Bad disc-error
sometimes the disks in the camcorder can get break down. its known problem is no working for long time. if everything on the disc are important for you  pls go to service. dont touch anything that you dont know.
have a good day.
May 28, 2009 | Samsung SC-DC164 DVD Camcorder
Player won't play any disc now
Time to look inside the dvd player. try readjusting the variable trimmer under the laser lens of the dvd player assembly. It is usually located under the lens assembly. try to adjust the lens at every 1 degree angle up to +/-5deg. sometimes it can be done. if not. time to change for new lens. damage lens is caused by using pirated DVDs or bad disc as the lens is trying to read the data on the cd.
guest.
Mar 13, 2009 | JVC DR-MV7 DVD Recorder/VCR
We have a yamaha dvd player, model number dv-s5450 and it won't play our dvds. Sometimes it works but sometimes it won't even read them, tried cleaning lasers with laser cleaner and that didn't work any...
I had a similar problem...the machine, which had been great up until then, started to be very fussy when loading a disc; using a lens cleaner did not help at all.
I opened the disc tray and used a can of "air duster" with the straw attachment blowing in lots of air into every little nook and cranny that I could reach, especially in and around the actual lens area. The liquified gas under pressure must have been too cold as, at first, there was no improvement whatsoever when I tried playing a disc. However, the next day the player was working perfectly again.
It is worth a try.
Nov 19, 2008 | Yamaha DV-S5450 DVD Player
Disk error message
In the manual there is a list of discs the unit wil play. On the last pages there is a quick reference. There are also region codes that need to be set. Maybe a power outage reset your settings. Also it would be good to know if this unit played disc previously, plays other disks? Or the discs play on other players. It could just be a dirt problem as well.
Manual is available here;
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Sep 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
No Disc
Get a new machine. Not "seeing" the disc could be bad laser, transport, electronics, on and on. Given the repair cost, a NEW one is your only practical alternative.
Mar 26, 2008 | Televison & Video
No finalising of discs.
USE MEMOREX DVD-R IT IS A HIGHLY COMPATABLE DISC AND HAS WORKED GREAT FOR ME
Nov 02, 2007 | Panasonic DMR-E50 DVD Recorder
Disc tray won't open
needs new tray drive belt
Feb 08, 2007 | Philips FWP900 System
SD-3109 DISC ERROR
Sometimes the motor that spins the disk will develop a dead spot where it will refuse to start up and spin, so my bet would be either the motor or the driver IC that powers it. Depending on your model number (it should have either a letter B,C,E or U after it) it may need the whole mechanism replaced. Also at around the 7th year, it has been my own experience that the laser pickup gets weaker and will either stop reading the discs all together or start skipping part way through, so a complete mechnism replacement is probably the way to go for this repair, unless you find that the replacement cost is under $150.
Jan 30, 2007 | Toshiba SD-3109 Multi-disc DVD Player
Open Questions:
See all Cyberhome CH-DVR1500 DVD Recorder Questions
Cyberhome CH-DVR1500 DVD Recorder Logo
94 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
