Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Color goes to black and white and back to color
While watching a show the color changes back to black and white and back to color
    Sergeant:
    Champion:
  • 346 Answers
Tuner problem
Posted on Nov 15, 2008
Everything that is supposed to be black is showing
Hi,It sounds like a problem with the color wheel or DMD board. The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will hear ,humming,buzzing,high pitch noises ,you might also experiment color distortion ,black and white picture. This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 29, 2010 | Televison & Video
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Black and white screen
I had the same problem. I fixed it by changing system settings, there is somewhere on the console where you can choose between two differant colour options. have a look around and try changing it on the ps itself.
May 03, 2009 | Sony PlayStation 2 (PS2) Console
Screen goes from color to black and white
replace the cable with a new one it should be fine after that
Oct 26, 2017 | RCA Televison & Video
Black and White
on a low signal input to the set the first thing you loose is the color, then it goes snowy and then just snowwhite in a snow storm or all blue with no sound.
check your cables for no shorts and loose connections,
sometimes the color killer control inside the set in the color circuit has to be tweaked alittle.
Jan 18, 2008 | Toshiba TW40X81 40" Rear Projection...
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Jan 13, 2018 | Sansui VRDVD5000 DVD Recorder/VCR
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
