Question about Yahoo Diamond Vision DVDC803-04 DVD Player
"wrong disc" message
We recently installed a new Diamond Vision DVD player. It tries to load but gives a "wrong disc" message in the upper right corner.
  • 513 Answers
Since the device is new, I suggest that you take it back to the shop, ask for a replacement and check it while in the shop to make sure its working. This is assuming that you made sure that you're trying to play the correct format discs. Consult the manual on which format DVD's it can support. Its multi-region so that can't be the problem, but its possible that you're trying to play other unsupported formats. Try also playing other discs - audio discs, DVDs, DIVX etc... make sure the disc isn't scratched badly. But the bottom line is you shouldnt have problems on the first day, take it back. Good luck!
Posted on Jan 25, 2006
Player just says loading
Have u tried a different Disc? If so the head might be dirty. try using a head cleaner.
Aug 18, 2013 | Yahoo Diamond Vision DVDC803-04 DVD Player
Dvd wont play says wrong disc
If this happen with all disks , then the lens are dirty or faulty.
Try cleaning the lens with a cleaner DVD. If that is not enough, then the player must be taken apart to clean lens with isopropyl alcohol and cotton, or to replace the lens pickup.
Before attempting repair call manufacturer or retailer to check warranty status.
Sep 10, 2009 | Yahoo Diamond Vision DVDC803-04 DVD Player
DVDV809-04
You need to convert your machine to an all-region player. The following hack works for Diamond Vision models 803 and 807 - there's a good chance it will work for the 809 provided they've used the same firmware for this model.
The region-free hack works as follows:
1.) Turn on the power and wait until the 'NO DISC' message appears, then press OPEN/CLOSE on the unit itself to open the door of the DVD player
2.) On the remote control, press SETUP. A menu will appear onscreen.
3.) Enter the following number sequence via remote: 1 3 8 9
4.) A different menu will appear. Your cursor should now be sitting in a box with the current region displayed. Use the UP and DOWN arrow keys on the remote control to display a specific region's numerical code, or select '0' (this is the number zero - not the letter o ... this is the region-free setting).
5.) Press ENTER and then SETUP to exit.
6.) Your DVD player will now play DVDs from all other regions. The code only has to be entered once. Powering down will not cause the Diamond Vision to lose its region-free setting. An added plus: it automatically senses PAL/NTSC signals but it will output to an NTSC tv set.
Sep 02, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
I have a remote diamond vision vcr/dvd
if yours plays DVD's I will take it off your hands.
The one I bought from Walmart has never played one disc. Always says wrong disk. Factory set for region 1 and I live and bought it in region 2.
Jul 13, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Diamond Vision DVD Player 803-04
call number of back of manuel and they can sent you one for 12. If you need number you can message me or look it up,
Jul 06, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Freezing
damaged or dirty disc-clean or replace
ron
Dec 27, 2007 | NexxTech DP3222 DVD Player
Wrong disc displayed
try to find crack for region code and set it up to be region free. that should do the trick.
Aug 14, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Diamond vision DVD player powers off when dvd is inserted.
your set needs the tech doctor you are having a problem in the power supply with your regulator or diode in the power supply.
Mar 05, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
"wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Oct 10, 2006 | Norcent Technologies DP313 DVD Player
Yahoo Diamond Vision DVDC803-04 DVD Player Logo
249 people viewed this question
Top Yahoo Televison & Video Experts
Craig Butler
Craig Butler
Ernest
Ernest
Are you a Yahoo Televison and Video Expert? Answer questions, earn points and help others
