Question about Sewing Machines
Elna 6000 Computerised Sewing Machine
Have been given one but have no instructions on how to use it. Is there a manual available
  • Anonymous Apr 01, 2009
    a present but no manual
Go to www.elna.com and you will find it there
Posted on Sep 18, 2008
Where can I find a instruction manual for Elna 7000
you can purchase manual this at sewingpartsonline.com
Instruction Manual Elna 7000 Computer
the 7000 was the last of computerised the models produced by Tavaro Switzerland, had some very nice features and big range of stitches. Circa 1987-88 I think.
Jul 08, 2016 | Elna Sewing Machines
Where do you oil the Elna 6000 sewing machine?
From memory these don't have a lube point, you just need to remove the bobbin case and brush out underneath it regularly to remove any lint or threads. There may be oiling wicks internally that a technician takes care of though so it pays to take to a trained Elna technician regularly. With the introduction of computerised sewing machines there was less metal moving parts, nylon gears and I think these had a couple of electric servo motors which do the work, rather than the old style sewing machine chassis.
Apr 07, 2014 | Elna Sewing Machines
Consult your owner's manual and oil ONLY as instructed. Be sure to use good quality sewing machine oil as recommended (NOT old oil from your grandmother's sewing basket, 3-in-1 oil, WD40, or cooking oil).
Apr 07, 2014 | Sewing Machines
Elna sewing machine 7000 geting bobin won't go through the feed dog
sorry, not sure I understand your problem. can you elaborate?
Have you got the correct Elna bobbin for your machine? check your manual, it should have an image of the bobbin, the 7000 was one of the last Swiss made Elnas and although a computerised machine, it still tool the Elna metal bobbin with 7 holes on one side only. If you are using another bobbin in the shuttle, it may not function correctly.
if you can add some more info I will try to help you further.
Oct 29, 2012 | Elna Quilter's Dream 6003Q
I have for gotten how to make the machine sew and im having trouble threading a bobbin for my moms machine elna 7000 i need a manual or a quick note to get started
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Jan 16, 2011 | Elna 2007 Mechanical Sewing Machine
My car was recently broken into and they stole my embroidery unit which was part of my quantum xl 6000. the problem is, is that they no longer make the sewing machine and iv'e made numerros calls and i...
I have a suggestion that may sound a bit over the top, Singer is no longer an independent company, it seems that Elna has bought or merged with Singer. Elna has a machine called the Xquisit and it is the identical machine to the Singer XL 6000, I have given lessons on the Elna machine by using my Singer to show what to do. You might contact Elna and see if there is someone to help with your problem or contact several service centers to see if they have any dead Singers and therefore orphaned embroidery units. Just a suggestion.
Gale
Jan 21, 2009 | Singer Quantum XL-6000 Computerized Sewing...
Sewing Machines Logo
296 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
