Question about Whirlpool GU2400XTP Built-in Dishwasher
Gu2300xt whirlpool dishwasher
Just bought gu2300xt. used 10 days, now click any button, it is not working any more and light no longer turns green.
5 Suggested Answers
SOURCE: Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Posted on Oct 09, 2007
  • 1894 Answers
SOURCE: my whirlpool du931scgb1 dishwasher.on the
this means the front buttons panel is defective
i would suggest you to change it with a new panel
Posted on Aug 01, 2008
SOURCE: Whirlpool GU1500 dishwasher - no wash cycle buttons would turn on
I had the same issue. If you have a 1100,1200,1500 etc you have the first series of the dishwasher and there is a heat sensor issue. The dishwasher runs and checks if the water heats up by 8 degrees. If the water doesn't heat enough then the washer will trigger shut down (assuming that there is an issue somewhere in the water heating process could be a variety of things) Alas, it may only be a one time issue and yet the programming in the dishwasher defaults to a shut down where the normal consumer can't get the machine to run. DO THIS: remove the kick panel on the front of the washer. Behind that is a document with a series of buttons that you push to reset the machine's computer e.g. you might have to press 'saniwash' then airdry then Saniwash then airdry. The machine will start the reset process and may also go through a 'cancel' function. After that you should be back in business. They have fixed this issue on the new machines so that the 8 temp trigger has to fail three wash cycles in a row before the consumer lock out is activated. As for those who own the first series....we do lots of resets. P.S. I learned this AFTER I bought two new panels for my GU1500.
Good Luck
Posted on Aug 27, 2010
rickead1
  • 1998 Answers
SOURCE: My whirlpool dishwasher has a
How many times is the green light flashing on the unit? Or is it just flashing over and over continuosly and not stopping. The number of times the light flashes usually represents an error code with the unit. Also try pushing sani rinse - dry button and then sani rinse - dry button then you should see the control panel light up after that hold cancel for 5 seconds message me back if this does not work. Also have you tryed shutting the unit off for 7 minutes at your breaker box sometimes this allows for the control to reset when this is done I await your reply To how this works with eliminating the blinking normal light Thanks again Rick
Posted on Jun 14, 2011
Whirlpool dishwasher wont turn on
first thing to do is to check if u have power to washer. check to make sure the breaker in your main electric panel is not tripped. If it is ok then take front cover off kick panel make sure that the wires running to the washer are not loose. be sure to turn off the breaker first. IF they are tight then turn on braker and check wires at washer connection with volt meter to see if u have power.
Apr 11, 2014 | Whirlpool GU2300XTS 24 in Builtin...
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Turn dishwasher on . the water loads in and then goes into wash cycle, it does it's wash cycle then drains and will not load clean water for rinse cycle it just hums a and then quits, then tries again and...
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool GU2300XTS 24 in Builtin...
Whilpool gu2300xt,wash cycle lights wont light,when i push start button goeswt calcell and drain and you can here drain pump then it shuts off
It is likely there is some fault with the float switch. Which means the dishwasher thinks it is overfilled with water and tries to empty out to protect itself. This is why the pump turns on as soon as you try to run the dishwasher. Refer diagram. You need to check if the float (12) spring is responding by pressing it down and checking if it comes up. Also level switch could be faulty.
Jan 12, 2013 | Whirlpool Gold 24" Tall Tub Built-In...
Residue left on dishes And glassware not properly rinsed and glasswre and silverware not shiny.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 10, 2011 | Whirlpool GU2300XTS 24 in Builtin...
Is there an installation manual on-line for a GU2300XTUBO Whirlpool dishwasher. Purchased May, 2010
Hi
You can download the manual by clicking on this link:
Whirlpool GU2300XTUBO
Hope this helps...please post back for further assistance.
Daniel
Dec 29, 2010 | Whirlpool GU2300XTS 24 in Builtin...
My dishwasher is not cleaning properly. The soap disoenser opens but does not empty out all of the soap. Do you ahve any ideas?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
mmnxv
Jun 30, 2010 | Whirlpool GU2300XTS 24 in Builtin...
Have Whirlpool dishwasher #GU2300xtsqo. White
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 16, 2010 | Whirlpool GU2300XTS 24 in Builtin...
GREEN LIGHT KEEPS FLASHING ON MODEL ADP 951 STARTS FOR A FEW SECONDS THEN STOPS
The same occurred with my dishwasher. I solved it by depressing the start button for 10 seconds. Worked for me...hope it works for others too.
Dec 04, 2009 | Whirlpool Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
121 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
