Hello
i have a lg plasma rz 42px11 which suddenly developed two vertical black lines,all other function work fine.
any advice would be welcome
many thanks
SOURCE: LG RZ-42PX11 42
Common problem. See this site -
http://www.forums.hcsd.com.au/Blah.pl?v-print/m-1175589480/
SOURCE: Hello, My LG RZ-42PX11 is broken. Only
The T-CON board is bad. However, these rarely fail on their own. I would suspect an over voltage from the power supply or damage from dropping. However the vertical lines are from the broken T-CON board that is on the top edge of the panel
Please accept if this answer is helpful!
SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
SOURCE: zenith 42" plasma p42w46x
I have the three zenith plasmas, I've fixed the two that were flickering. The one with the verticle lines, I sawpped the Z-SUS and the Y-SUS from the good TV to the bad and still had the white lines. I looked at the two boards hooked together with 3 aluminum covered ribbon cables that are in the lower center of the TV with all the video inputs, on the far left there is a right angle connector that has about 20 pins, the white cable comes out and goes under to a circuit board this looks like this cable supplies the video signal to the screen. I disconnected the cable and the screen went black, all the voltages going into the video board are normal, so there must be something fried on one of the two boards, there are a LOT of electrolytic caps on those boards. I will post when I figure out whats cooked, you may have the same problem too.
SOURCE: Zenith P42W34 EDTV Plasma Black Line
Just reheat and add soder to fuse connected behing the driver boards.
I've got the RT42PX10 and same problem. Going to look for dry joints and just re solder them again.
I HAVE A PLASMA LG RZ-42PX11 AND APEARS ONE 3cm VERTICAL BLACK BAR COMES AND GO DEPENDS THE CHANAL , I FOUND SOME INFORMATION ON THE NET TO SOLVE THE PROBLEM HOPE IT HELPS . ANTONY.
keep getting a black vertical line on the screen sometimes?
identical problem as above any help would be good
