Question about Sony STR-DE595 5-Channel Amplifier
Composite video I cannot get my STRDE595 to switch any composite video. The component video works fine. When I switch to Video1, Video2 or DVD, I get no video to my TV, but audio works fine. Is composite video supported on this amp?
  • 10,594 Answers
According to its service manual, Component Video (STR-DE595 only, except for
models of area code AEP, UK):
Is it is UK region, it support composite video.
Regards,
Posted on Sep 07, 2008
Could you tell me the steps to hook up my vcr & my dvd players to my tv. And what cables and or devices I need to accomplish this task?
It will depend on the devices. Most VCRs will have composite and S-video outputs. For this you will need either a composite audio/video cable (3 RCA plugs on each end: yellow (video) and red and white (audio)) or an S-video cable and a separate audio cable. The DVD player will probably have component video or HDMI outputs, depending on its age. The component video requires a 3 plug RCA video cable (red, green, blue) and a 2 plug RCA audio cable (red and white). Some DVD players have composite outputs as well. However, this limits you to an SD video output and isn't recommended, unless your TV doesn't have any HD inputs.
If your TV has one each of the appropriate input ports or 2 composite video ports, you just need those cables, assuming you have no other devices that have filled the inputs. Always connect the devices with the TV and the A/V components off. Match the color of the plug to the port. If you mix up the colors on component video cable, you may get a black&white picture. Some newer TVs use an adapter dongle to convert composite or component video to single port on the input board. Again match the colors at the dongle and then plug in the adapter. If your TV has shared composite and component signals, use the HDMI port output on the DVD player, if possible, or get a Audio/Video switch, like this: http://www.amazon.com/Panlong-Switcher-Composite-Selector-Consoles/dp/B00KXVBB3Q/ref=sr_1_24?s=audio-video-accessories&ie=UTF8&qid=1440632814&sr=1-24 .
Please add a comment with the make and model of your specific TV, VCR and DVD player. I hope this helps.
Aug 26, 2015 | Televison & Video
How do I hook the dvd player to the tv???
If your TV has composite video inputs, use the A/V cable that came with the player. Connect the black mini-plug to the AV out on the left side of the DVD player. The other side has standard composite video (RCA jacks); connect the yellow plug to a composite video in jack on the TV. Then plug the red and white plugs to the matching Audio in for that composite video connection. If you do not have the adapter, get a replacement like: http://dynexproducts.com/products/cables-cords-adapters/DX-AV071.html .
If your TV doesn't have composite video inputs, you will need the appropriate converter depending on the TV. Most likely you would need a composite video to RF converter (an RF modulator) like this: http://www.hdtvsupply.com/rfmodulator.html . (Most TVs with component video and HDMI ports will also have composite video jacks.)
I hope this helps.
(If you have enough devices that you need a switch, you can find them in stores like Radio Shack. If you want to convert to component video, those converters also exist. However, each converter will degrade the signal a bit.)
Nov 18, 2010 | Dynex DX-PDVD9 Player
I can get composite video signal from coby dvd, but the component video shows no picture. Audio is OK. What could be the problem.
Are you using component video cables for the component outputs on your tv? Plugging composite cables into component output generally will produce poor if any video.
Also, check the back of your dvd player to see if you need to flip a switch to enable component video output. Good luck.
Aug 21, 2009 | Coby DVD-224 DVD Player
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Dec 17, 2007 | RCA F32650 32" TV
Can't get componet Video to work
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
Aug 10, 2007 | Yamaha HTR-5930 Receiver
Sony STR-DE595 5-Channel Amplifier Logo
129 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
