RCA RS2635 CD Shelf System
Problem for RCA RS2635 CD Shelf System
No Sound
By Guest on Jan 25, 2006
No sound on any of the options. Will correct itself for awhile if unplugged, then plugged back in.
Best Solution
posted on Jan 25, 2006
Very Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3610 votes
First of all the obvious - Do not open up the system unless:
1. you have some experience with electronic repair.
2. you're out of warranty.
If under warranty or over your head you can still try connecting the system to a known working speaker, just to rule that out. Other wise take it back to the shope you bought it from, or consult a repair person.
If both 1&2 apply to you check the following suggestions:
1. Feed in a signal, as such from an audio generator, and follow the signal path with a scope. Where the signal stops, is your dead area.
2. Take care that you properly check the power supply. Use a scope to see where the audio signal stops along its path to verify.
3. The output IC is most likely defective, and some of its support
components along with it. You have to try the IC to test. If the cause
of it blowing is not fixed, the new one will blow right away.
4. there is a transistor on the main board which goes bad on these.
Near the center of the board, you'd see the overheated area.
5. RCA has a nack of using low value resistors as fuse devices in these sets, when an output device fails or overloads it normally will open the associated resistor (fuse).
Fix it and crank it up ;]
You rated this solution as "Very Helpful".
Popular Solutions for RCA RS2635 CD Shelf System
Questions and Unsolved Problems for RCA RS2635 CD Shelf System
Do you recommend RCA RS2635 CD Shelf System?
Answer
Answer
There is no sound coming out. Everything is hooked up correctly,its not on mute and the head phones... (More)
Answer
our audio rs2635 sound output ic is burn sp iwant to know this ic nomber
Answer
ok, so I have this rca Rs2635 cd shelf system, and it apperently plays cd's and tapes. but all I... (More)
Answer
my stereo has a buzzing noise out of both speakers when it is turned off or on unless it is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA RS2635 CD Shelf System:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
