Question about Whirlpool LSB6200PQ Top Load Washer
Cabinet putting it back on
Trying to put the cabinet of a series 90 kenmore washing maching back together any suggections would be great, it isn't lining up.
Got the problem taken care by located the tabs that lock the cabniet back together on the base. Everything then lined up prefectly. It is more than a 1 man job...lol
Posted on Sep 08, 2008
I have my Kenmore series 90 washer transmission disassembled to put on a new part. Now, I can't get it back together. Help
Can you tell me exactly what you did to remove it...and what part are you going to put on??
Jan 28, 2011 | Washing Machines
I just replaced the motor coupler on my Kenmore series 90 washing machine and after putting everything back together and starting a wash cycle, a burning smell is produced. Any idea why?
I'd pull the cabinet and check the coupler again.
If it wasn't fully seated on the transmission and motor shafts, the pins on the plastic pieces may not be making full contact with the rubber center section.
I'd also make sure that the motor was re-connected correctly.
See the following Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Another way to check is to pull the cabinet, bypass the Lid Switch by jumping the two outside connections with a short piece of insulated wire and re-start the machine. You should be able to tell where the "burning" is coming from by looking at the motor, gearcase, coupler etc.
The service Manual shows how to bypass the switch also.
Dec 18, 2010 | Washing Machines
How do i remove the tub on a kenmore series 90 washing machine?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
To remove the tub, you'll have to remove the agitator(s), cabinet, the spanner nut and drive block.
See the following illustrated guide. You don't have to pull the pump, motor or transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=bce33cd8b32f440a0adb6e8170d95aea
You also don't have to buy a special spanner wrench. I've used a short (10") pipe wrench hooked around one of the tabs on the spanner nut and by tapping the handle of the wrench, the nut should come loose.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap it up.
Make sure that the tabs on the drive tube align with the slots in the drive block when putting the washer back together.
Nov 14, 2009 | Kenmore Washing Machines
Won't spin or rinse, took clothes out .... too heavy maybe??
you have a bad lid switch,you can by pass it,remove the switch,put the pos.neg. together with wire nut and your finished-mike
May 20, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
RE: Putting whirlpool washer back together
I would agree with you, it sounds like it isn't going back together correctly. When I put the cabinets back on them, I first make sure all 4 of the spades sticking up from the base are straight and not bent over. Next I grasp the hole the lid covers towards the front and lift and pull it towards me so the bottom of the cabinet is closer to me than the top. Next, I use my foot to push the bottom of the cabinet under the bar that goes across the base of the machine. Then I tilt the top of the washer back towards the machine. I wiggle the sides, until the cabinet seats into the spades coming from the base. After it seats properly, the clips should be lined up properly to be installed.
Jun 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washer leaks after installing new lid switch
Glad this was taken care of. I'm just closing out some old tickets here.
May 18, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSB6200PQ Top Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
