Question about Epson Stylus CX4600 All-In-One InkJet Printer
Printer won't print
I have an epson CX4600. I changed the ink and when I print it will put the paper through like it printed the paper is blank. It also says my ink is low and I need to change it.
  • 1 more comment
  • Anonymous Sep 20, 2008
    I have the exact same problem. How do I resolve this issue?
  • c3taz3 Sep 25, 2008
    Have changed the cartridges twice. Printer seems to eat the ink and paper is still blank. Have run the maintenance several times with no results.
  • lilylou Oct 19, 2008
    paper goes through like in printed but doesnt this didnt happen till i changed ink
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
Posted on Oct 05, 2008
Only blank pages
The print head, which is integrated into the machine, is dried and clogged. You probably could have guessed that. If you and cautious and daring you can attempt the disassembly of your machine to extract the print head. Be very careful and remember where everything goes and in what order. Anything you de-grease, re-grease. The print head is the component that your printer cartridges hook into. Once out the bottom side will look like a large gray square. The best you can do at home is to set in on a folded paper towel thoroughly dampened with distilled water. Let this sit over night in an area that seeping ink will not damage anything, i.e. on a plastic disposable plate. If in the morning you see the four colors flowing you may have success upon reassembly. The worst you can do here is not get it back together and then you're at the same place you are now. Good luck, email with questions.
Feb 02, 2010 | Epson Stylus CX4600 All-In-One InkJet...
It will not print. It has new ink cartridges..There are no error messages. Print heads have been cleand several times. It will not print a test pattern. It will not make a copy. Only blank paper comes out.
Head cleaning is mechanical process, printing is electrical process. Nothing print out at all? Printer mainboard problem. Lost electrical to head. Usually caused by short circuit at head. Track on aicaxz solution for reference to repair board. Note: if you have experience in electrical circuit, test mounted fuse at board.
Dec 31, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
http://www.ssclg.com/epsone.shtml
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson stylus cx4600 all in one
remove the printer inks & use soft issue paper to clean the printing head. how long have u be using this ink on the printer?. check for the ink level if its too low, the output will be very faint.
thanks. let us know if we should add more tips.
Oct 05, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Ink not present when printing
If the printer went through a period of disuse, I recommend you read my solution the thread at http://www.fixya.com/support/t743789-printer_will_not_print_even_though
Apr 10, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Possessed epson stylus printer #cx4600
i would suggest this http://www.supermediastore.com/cleaning-cartridge.html or a similar product from a different supplier..
Happy New Year
John
Dec 05, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Paper comes out blank
epson cx4600 prints blank paper replaced ink cartages .same problem
Dec 02, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Cx4600 epson
Jets are clogged Needs deep clean. 1st try -www,ssclg.com The Epson utility. Run the program- select your model- right click on the icon on the bottom task bar. 2nd Take a look at www.fixyourownprinter.com. 3rd make your own cleaning tool as here
May 18, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
159 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
