Air floww block tv will shut down - Televison & Video
There was a letter sent to owners of the WD-57731 stating that there is a loose connection on the thermal sensor and a 1 year warranty extension has been given to replace the thermal sensor. Call 1-800-332-2119 for more info.
Posted on Nov 08, 2008
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
I get a message that the air flow/fan is blocked, then the tv shuts down. It's not blocked. It's perfectly clean.
This indicates the TV is overheating. Lamp based TVs usually have two or even three fans. One may be having problems or not turning fast enough.
Mar 31, 2010 | Televison & Video
Tv blacks out and saids block air flow
Call Mitsubishi and they will tell you a authorized service center in your area to come out and fix this issue. They have a recall on the thermal sensors in these sets. They will pay for the repair.
Oct 17, 2009 | Televison & Video
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Message on screen says tv will shut down ck air vents for blocks
you must have a wd series mitsubishi..the lamp tempurature sensor has a manufacturing has an updated one to take care of the problem..the sensor itself is not bad it is the way the wires are crimped in the plug,,the new one is soldered..the part number is 299P313010A,
Sep 17, 2007 | Mitsubishi WD73727 73" HDTV
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
