Question about HP OfficeJet 6110 All-In-One InkJet Printer
Does not print
Even though I received faxes, and the self test was fine, when I print from the computer the pages come out blank...
  • 1 more comment
  • thacker55 Sep 11, 2008
    my self test page and printing prints colors but no black, absolutely none--. The ink cartridge was low and I refilled and cleaned it and now it won't print at all. Anything I can try before I buy a NEW cartridge?
  • gugajoyce Oct 18, 2008
    MY HP PRINTER WILL NOT PRINT FROM MAC COMPUTER
  • thacker55 May 11, 2010
    I ended up buying a new ink cartridge and it worked fine immediately. It seems I can only refill one a couple times then I have to buy a new one. Is that common? But thank you for responding, appreciate your advice!
    New Friend:
  • 109 Answers
Check your printer configuration and default setting choose the name of your default printer.
Posted on Oct 17, 2008
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have an hp printer p1505, the paper jam is always on
I just had this issue and called HP. Even though the printer was out of warranty, I was able to go through some troubleshooting steps over the phone. IF you open and close the top cover 5x, it will print out a self test page. That is the only self test page that prints. Afterwards the computer will detect the printer and it will print just fine.
Dec 20, 2008 | HP Office Equipment & Supplies
Hp5510--will fax, bukt when it prints, the sheet is blank.
First print a standalone test page.
Push Setup >> Print reports >> Self Test report.
If the page prints fine. Reinstall the software. It will work !!
Best Of Luck.
Dec 01, 2008 | HP Officejet 5510 All-In-One Thermal...
Fax
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
Mar 04, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Blank Pages Printing
Does the printer show up under "Printers and Faxes" on your PC? Click on Start / Printers and Faxes ...to see if it's there? If you see other printers in the "Printers and Faxes" window...is your 6110 listed as the Default printer...that is...is the icon for your printer marked with a small checkmark?? Is there more than one instance of your printer in the "Printers and Faxes" window? If so, you should delete all but one and make sure the remaining one is marked as the default printer.
Jan 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
41 people viewed this question
Ben Johnson
