Question about Sharp Microwave Ovens
Microwave oven carousel not working and microwave not coming on, only time is working. Model R-52OL-K. Brought at. LOWE'S Cotati, CA 94931 12-24-2006
  • Sharp Master
  • 9,086 Answers
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Acrobat Reader to view or print it.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 16, 2008
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
I have a sharp carousel but the convection oven is not heating up. The microwave works.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';
May 24, 2011 | Sharp Carousel R530EST Microwave Oven
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
How do you turn the carousel on/off on a Kenmore Microwave Oven model: 5658932580
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
Nov 08, 2009 | Microwave Ovens
Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Oct 14, 2009 | Sharp Microwave Ovens
Timer works light comes on timer goes down but no inside power
You have a bad primary interlock (bottom door switch) or its mount is broken, loose, or misaligned.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
If you need other parts, you can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 23, 2009 | Sharp R-401CW Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave Ovens Logo
64 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
