Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Dell latitude problem
Notebook adapter work fine the first time. When I restarted laptop it lock up.
removed card and computer works fine but when i install card it locks up
  • 19,396 Answers
Unplug card, reinstall drivers and put back card.
If system is still freezing the card may be defective.
Posted on Sep 07, 2008
Laptop screen appears to be solarized
Step 1:
The drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers Make sure there is no dust in the socket you might have to physically remove your card to restart your computer this will activate found new hardware wizard Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red X right click select reinstall drivers If your computer came with a motherboard disc the drivers could be on it
Feb 20, 2013 | Dell Latitude D620 Laptop (Latitude-C620)...
Why does my dell latitude laptop direct me to reformat my SD cards every time I insert them
Sounds like you might need to download and reinstall the SD Card Reader Drivers on the laptop.
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 21, 2012 | Dell Latitude D420 (D4202G-B) PC Notebook
Hi , I have Dell Latitude D600 Laptop, it is working fine but a few days ago , it gave an Error on Boot Screen "Unknown AC Adapter...." while there has been no change in Adapter , Battery or any Hardware....
The Adapter should be able to run the laptop and keep the battery charged. Take adapter to a shop and have it checked. If good then the connector where it connects to laptop is probably bad.
Aug 18, 2010 | Dell Latitude D600 Notebook
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Battery light on dell latitude d410 continously flashes yellow/orangish. Does this indicate a bad battery. Works fine with cord plugged in.
    There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
    If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
    To verify this, unplug your laptop & try to run it on battery only. Watch out how long it will stay on (if at all). If it didn't work on battery alone, or worked but for a very short time, then your battery is defective.
    Mar 17, 2010 | Dell Latitude D410 Notebook
    Dell Latitude 505 that will not run on AC
    Sounds like a BAD adapter. When was the last time it worked in the laptop?? I would try another adapter if possible. When was the last time the adapter work on the laptop?
    Jun 03, 2009 | Dell Latitude D505 Notebook
    Laptop Will Not Turn On
    first remove batterry from it for 5 minutes ckean its from, dust.
    May 08, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
    Dell Latitude D620 locks up when moved
    Is this when the ac adapter is plugged in?? Or on Battery??
    Feb 06, 2009 | Dell Latitude D620 Notebook
    Dell Latitude C540 screen goes dark when adapter is pluged in
    Right click on the battery icon on screen and set the power and screen brightness as you require.
    May 02, 2017 | Dell Latitude CP DC Board Graphic Card
    Open Questions:
    Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
    98 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
