Question about Panasonic Televison & Video
I just replaced a lamp on my Panasonic PT43LC14 43. Now when I turn it on, the lamp turns on for couple of seconds and then TV turns off an red light flashing. Also the lamp fan is constantly on. I think something wrong g with thermal sensor.
  • Panasonic Master
  • 1,525 Answers
Hi, make sure the lamp is fitted securely and also the lamp cover.you will have to reset the lamp counter good luck
regards
shaun
Posted on Dec 09, 2011
Did you ever get your problem fixed? I have the same problem now...elf
Posted on Sep 15, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I replaced my lamp on a panasonic pt-lm2e with a new lamp same model,once i power it on it shuts down after 2 seconds,why
google ur model and how to reset the unit. normally
its holding down a couple of buttons. good luck
Sep 19, 2014 | Panasonic Televison & Video
Panasonic TV shuts off after a couple minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic TV
Good Day,christie511;
It sounds like the lamp is in need of replacement. You could call a service company to replace the lamp, but it is so easy to replace the lamp ones self. So, call Panasonic and order the lamp, they will send to your home with instructions.
Three screws and your home free!
Good Luck, Big Irish.
Jul 08, 2008 | Panasonic PT-45LC12 45" Rear Projection...
No light come on from the projector
Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
good luck
smeags
Jan 02, 2008 | Hitachi CP-X260 LCD Projector
Televison & Video Logo
162 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
