Question about Kenmore Washing Machines
Laundry Center Washing Machine Leaks
I am attempting to repair a Kenmore Laundry Center that leaks. The leak is coming from the bottom of the tub where the transmission shaft connects to the tub. I have been able to remove the drum, but I have gotten stuck on the next step. I believe I need to remove the "upper housing assembly" (pictured, name from the parts diagram), but I have been unable to determine how to remove it. I have not been able to unscrew the silver piece above the shaft. Perhaps there's a trick to it.
Thanks in advance,
Dlockwo
  • 4 more comments
  • dlockwo Sep 07, 2008
    Model No. 41799170100
    Kenmore Laundry Center Model No. 41799170100. I have been able to find some parts diagrams from www.searspartsdirect.com, but I was unable to figure out how to remove the upper part of the transmission from the diagrams.
    Thanks,
    DLockwo
    I actually would like to know how to remove the upper housing assembly from the transmission in the drum. I am aware that I can remove the entire drum from the machine.
    This solution did not assist me in removing the upper housing assembly within the drum. I do not want to remove the drum from the machine. Please explain how you disassembly the transmission assembly.
    Ginko,
    Thanks for you solution. I will check it out. My response was Junoon007.
    The diagram is not applicable to my machine unfortunately.
  • 2,071 Answers
To unscrew the silver piece above the shaft put a penetrating oils,an oil with lighter than lubricating oils and do not offer much friction reduction,they are formulated to penetrate corrosion,such as rust, try to clean off the excess corrosion if you can, Always Shock the assembly by carefully tapping on it, if you can, with a hard implement such as a or wrench. Do this carefully so the shafting will not damaged.To stop the leaks put a marine epoxy to the leaks affected.. hope this may help you; Regards, VOTIT
Posted on Sep 07, 2008
    Brigadier General:
  • 5,158 Answers
Likely a C clip that holds that shaft on... the clip will have two holes on either end of it. you can remove the clip with a screwdriver by prying on both sides at the same time but there doesn't look like a lot of room there.... invest in the tool for the removal of those clips... you may have to remove some of the corresion to see it.
Robert
  • 1,031 Answers
Here http://www.repairclinic.com/0100_23.asp is a detailed discription that will guide you all you have to do is move your move to get a full pictorial view and the next step including how to order for the parts .hope this helps
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
When the drum has been removed(pull the drum up at the rear to get the ball-shaped rear bearing out of the bearing holder)you'll see two 5/16 screws that secure the rear bearing. The stainless steel bracket at the rear of the dryer is where those screws go into. In your case--it is problably a good idea to have a helper get behind the dryer to hold this bracket while the screws are removed/installed. A small ball bearing is also under this bracket--this is the drum *ground* circuit. addthis_pub = 'ApplianceBlog';
click this link for more details
http://fixitnow.com/wp/2007/05/16/getting-to-the-lid-switch-in-a-kenmore-top-loading-washer/
http://applianceguru.com/forum2/834.html
Thanks
good luck
  • Kenmore Master
  • 19,396 Answers
Post the washing machine make and model, I see if I can find specifig diagrams for your appliance.
  • 1 more comment
  • Ginko
    Ginko Sep 07, 2008
    Here is a general diagram for a top load WM, similar to yours, browse the mouse on the picture, until you get visualised the mounting stem and boot seals.
    This is common cause for leaks from the central part of the tub.
    Post the complete model number, so that I can give you exploded view for your appliance.
  • Ginko
    Ginko Sep 07, 2008
    I found all parts for your appliance here, I haven't found a diagram.
    There is no truck to remove the stem, you just need a good wrench.
    I see if I can find some schematics.
    In the meanwhile check inside the washing machine, some Kenmore has schematics and assembly instructions sealed in a plastic envelope on a side panel inside the machine, take a torch light and have a look.
  • Ginko
    Ginko Sep 07, 2008
    Ok, I was looking for a downloadable diagram for the machine, unfortunately I found none.
    Here is another part seller, with all parts for your machine.
    If you are really in trouble call one of the parts seller, and ask if they can send you the service manual or the exploded view for your model.
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Washing machine is leaking from the bottom of the tub. model flse60rgs1
Hello there diana and welcome to fixya
Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Dec 18, 2011 | Kenmore Washing Machines
Kenmore washer leaking water out bottom in rinse or spin cycle.
Jan 24, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Leaking from the bottom of washer
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem that you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. If that happens, the entire outer tub would need replaced, but that might not be an economical repair to make and would require professional assistance. Hopefully, the main drain line is leaking and can be repaired. Sorry for your trouble and I hope this helped. Best wishes
Sep 13, 2009 | Washing Machines
Maytag A806 washing machine leaking from the center,under the tub
The tub seal is bad.
I had the same issue on another model.
You can attempt to repair this yourself. I suggest that you do a search on Youtube to see if this is a job you want to take on. It took me 2 hours to change mine. The seal kit and tools are sold online.
Good luck.
Sep 27, 2017 | Maytag Washing Machines
Leaking below washer
Sounds like you have a leak from the tub. Either the seal in the bottom of the tub or a hole in the tub.
When you run it again try feeling around the bottom center of the tub for water or try to see if water is leaking any where out of tub. Clear water would be from the supply line , soapy water would be from tub or a hose coming out of tub.
Jun 09, 2009 | Washing Machines
Tub leak on a Kenmore Washing Machine Model
you could probalby get away with a marine epoxy to repair thecrack (depending on size) , althouth replacing the tub would be the best "feel safe" --- "no longer worry about possible floods". buthte cost and time to switch the puter tub is problably cheaperto buy new machine
Mar 24, 2009 | Kenmore Washing Machines
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
Leaking from the bottom.
KENMORE WHAT ???? DEPENDS ON WHAT MACHINE UR TALKING ABOUT???????
Nov 25, 2008 | Washing Machines
Washing Machines Logo
159 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
