Question about Lands Phones
Model # TGA931T
This model has the main phone and two extensions that plug into an outlet. The problem is when the phone rings. They randomly do not work. They will ring once and then not ring. If you pick up the phone and push talk it says that it is not connected to the base. Sometimes it works sometimes it doesn't. Sometimes one works and the others don't they don't seem to have a pattern as to which one will work. I am very frustrated, any help???
  • ldmartindale Dec 11, 2008
    Model # TGA931T problem Same model and same problem
  • 19,396 Answers
Try to unplug all power cords, this will reset the phones.
Try to swap the two phones.
If you still cannot fix it , then one of the phones is faulty.
Posted on Sep 07, 2008
Need a manual for a Panasonic phone and answering system KX-TGA931T so that we can set the number of times that we want the answering machine to ring. It rings too long and we're callers are hanging up...
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Hello I recommend you check out this link. It is not your specific model but is quite similar. For ringer settings, go to the section about answering calls. I did not see anything about changing number of rings, but I could have missed it.
Oct 10, 2013 | Panasonic Lands Phones
NEED USER MANUAL FOR KX-TAG931S PHONE HANDSET What I really need is how do I make the incoming call go to Voice Mail without it ringing 4 times.
You may download the KX-TGA931 manual from http://shop.panasonic.com/shop/model/KX-TGA931T?support
The number of rings is controlled by the answering machine or voicemail system on your phone line. It cannot be changed from the handset. Please refer to the documentation for whatever answering machine or voicemail system you have.
If you require further assistance with the answering machine or voicemail system, please tell us the make and model.
Sep 23, 2013 | Panasonic KX-TG5210M GigaRange Supreme 5.8...
Need Paasonic phone manual KX7GA931T
May I assume you mean the KX-TGA931T? If so, you may download the manual from http://shop.panasonic.com/shop/model/KX-TGA931T?t=manuals&support#tabs
Jul 25, 2013 | Lands Phones
How do I change the current extension on my polycom 301 phone from 334 to 300?
Go to support on the new phones manufacturers web site and you can download an owners manual, which will tell you how to re-program the phones extension. murf427
Aug 01, 2012 | Polycom IP 301 SIP IP Phone
How to reset the alarm ?
here i attached the link for the manual of KX-TGA931T
http://www.scribd.com/doc/4242810/Panasonic-KXTG5050W-58-GHz-Cordless-Phone-Manual
May 17, 2010 | Panasonic KXTG2344 Cordless Phone
How do i add a new phone to an existing system? I have connected the phone & just need to assign an extension number for it so that the other phones can see the system, thank you
If you have installed it on a new extension, it already has a number. By default, on a TA-series system, the jack and extension are the same, so Jack 12 is extension 112. Quickest way is to plug the phone in and dial 0. The main phone rings and the display will give you the extension number.
To program the buttons, press PROGRAM the button and dial 1 plus the extension number. The lines should already be programmed by default, but they are 0 plus 01, 02, 03 etc. Press STORE after each button you program.
If you want to program ringing and line access differently than it already is, you need to look in the Programming Manual for the specific phone system. The Panasonic cabinet is going to be white with a silver tag or a model number stenciled or embossed on the case. Something like TA-824 or TA-624 would probably be your system model.
Carl
Dec 15, 2009 | Panasonic KX-T7730 Corded Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
The ringer is turned off on my Panasonic cordless phone.
you go to profiles and select customize and then you can select the ring on or off for the incoming calls,msg....
Jul 14, 2009 | Lands Phones
Ringing everywhere
If it used to work and stopped, I'm guessing the system is no longer in the DAY mode. Each system tends to program differently and the 7730 phone can be plugged into one of about 18 different Panasonic systems.
From the main phone, try dialing 780#. If it beeps and says DAY MODE, it was the right command :-) Now test the lines and see if that fixed it.
If it doesn't work, please go to the phone closet/back room/attic/whatever and grab the model number of the phone SYSTEM and post back.
Carl
May 11, 2009 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
132 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
