Question about DeLonghi Magnifica 3300 Espresso Machine
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
    New Friend:
Is the machine new? Then you must set the water hardness, using the procedure described in the manual. Set the value corresponding to the water hardness in your area. Once this has been done, the machine will prompt you to descale after a certain number of cycles; follow that procedure, and the light should go out when you're done.
Posted on Mar 19, 2019
    New Friend:
Identical problem ! The machine continues to make coffee though...has anyone any ideas how to rectify?
Posted on Apr 04, 2013
    New Friend:
After descaling the machine, the green lights won't stop flashing and it won''t reset itself back to normal. Ipressed both buttons to put it into descaling mode and then it says to press both buttons again to reset it. Just won't work. Stays in descaling mode.
Posted on Jul 27, 2013
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Posted on Aug 20, 2011
SOURCE:
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Des along light still flashing after des calling process completed can anybody help
if the descale posses interpreted its wont tern off
you have to go to menu and adjust the water hardness then do the descaling in full posses
Apr 14, 2015 | DeLonghi Magnifica ESAM4200S Espresso...
Why doesn't my descaler light ever go off from flashing?
Perform the full descaling program as described in the manual to reset the descaling counter.
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I have a descaling issue with my DeLonghi Magnifica ESAM3300. I emptied the tank and added the bottle of DUR-GOL descaler plus one liter of water as requested. I then put a container with a minimum...
It means a half of a full revolution (180 degrees), Not a half of a knob turn (90 degrees). 90 degree on the ESAM3300 doesnt do anything. Turn the knob a full 180 degrees to start the descaling
Jun 29, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
The CLEAN light has come on. How do I clean it?
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Descaling coffee makes esam4200
100ml of descaler per tank of water. then they say 1 rinse, but I have to rinse 5 times to not taste the descaler anymore.
Jul 21, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Magnifica 3300 Espresso Machine Logo
5,660 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
