Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
WFMC1001UC door locked
Bosch WFMC1001UC washer: after running a load, the lights are off, and the door is locked. The wall outlet has power, but the door remains locked, and the lights remain off. Is there a way to open the door while I wait for service?
  • wndsrch Sep 07, 2008
    I found a partial solution to my problem: First, I unplugged the machine and turned off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. I inserted a piece of wire into this hole, and pushed in gently. While pushing, I turned the cover clockwise, and it came off.
    The door release is a narrow white plastic strip hanging down on the right; I pulled down on this strip while pushing in on the door, and the door lock released.
    It turns out that the machine stopped part-way through a wash cycle; now I just need to wait for a service call.
  • 1,031 Answers
There are safety devices that can prevent you opening the door or lid while the washer is spinning or agitating. This is for your protection, so don't circumvent these safety devices but after running a load and the door remains locked press reset button on control panel if it persist make sure the timer is properly set test timer if faulty replace check the lid switch remove detergent build up from orifice if any test switch it might be faulty then replace dont forget to rate this solution
Posted on Sep 07, 2008
Why does Bosch Nexxt washing machine act like it is unplugged, even when connected to power?
Either no power at outlet or electronic control module faulty
check power at point with say a hair dryer
if ok electronic control will need replace
Aug 05, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Door will not lock
Possible that the door lock is jammed or there is no trigger from the door switch or lock. Also this can be due to fault in the control panel, check the input/outputs from the controller unit.
Click this link: door lock
Jan 21, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Manual release on door lock of a bosch nexxt series 100 washer
Try pulling door up before out. My washer does this when the rubber around the door gets a piece of wet paper under it, or I have overloaded it and the rubber gets moved. Once open, run your fingers around the rubber seal to verify nothing under it and that it lays smooth.
Jan 03, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hello - we have a Bosch Nexxt 100 Series Washer. The front loader door is locked and I cannot get it to unlock. We have a load of clothes in the washer. I have tried to run the "spin" cycle...
Easy to do....But may need a service call from a pro to fix the underlying issue.
Take the bottom right little door off and try not to cut yourself reaching in..(OH TURN OF THE POWER). reaching in after looking with a flashlight try to grap the zip tie looking plastic hanging there and pull it down gently and it will unlock.
Of course make sure you tried to unplug it first for 10 minutes and then try turning it on again in spin mode.
Thanks,
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
The door is stuck on lock. Will not finish rinse cycle.
The door lock is design to stay locked if the water level is above a certain level, therefore it is possible that you have a blockage in the outlet hoses or an obstruction in the pump. At the bottom of the front panel there should be a flap that will expose the pump and possibly a small hose to empty the w/m manually. Check you manual for the procedure. Follow link if you can't find your copy.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Jul 07, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Clothes in door locked, beeps and will not start. panal lights o
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is for the WFMC6400, but it could help.
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and
locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch
assembly is a teardrop shaped tab.
Gently pull the tab down approximately 1/4 inch,
or until a click is heard.
5. The door may now be manually opened.
Pl give me a ‘very helpful’ rating for the free help, thanks!
Jun 01, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
341 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
