Question about Kenmore 23822 Top Load Washer
Does not spin
My Kenmore 80 Series Washer does not spin, but it pumps out water. What can I do to fix it?
  • 550 Answers
There is a coupling between the motor and gearbox, that fails.
it is a simple repair, and well worth trying
remove cabinet
  • pop off edge trims from control console
  • remove screwss from under edge trim
  • slide console forward and up ~1inch
  • flip the console over the back of the washer, the hinges are plastic and a little fragile
  • remove brass clips holding cabint inplace remember how they fit
  • lift cabinet ~1inch and remove forward
repair coupling
  • motor gearboxpump is at front bottom center
  • remove lock screw from clip holding pump to motor
  • remove two spring clips
  • pull pump off motor and swing sideways on hoses, tie off to left with a string
  • remove lock screw from clip holding motor to gearbox
  • pull motor off rubber coupling
  • pull nylon spider off gearbox shaft
  • pull nylon spider off motor shaft
  • install new spiders to shafts. Use a hammer to strike a wooden dowel on the center of the spider, dont hit the legs of the spider they break off
    Note the new coupling spiders have metal centers to stop further breakage, common fault
  • turn gearbox spider 1 leg up two legs down
    turn motor spider , 2 leg up 1 leg down so the spiders will interlock
  • install new rubber coupling on gearbox spider, install motor on coupling.
reassemble all clips and screws in reverse order
reassemble case in reverse order
on reassemble ensure plastic level sensing hose is not dislodged from water level switch body
takes longer to type than to do the repair
at parts store "Kenmore gearbox coupling" will get the correct part
Posted on Sep 07, 2008
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
Washer won't drain or spin
you need to check the water pump... it may be clogged with detergent or something to that effect.. or just replace the pump itself..
Oct 11, 2009 | Washing Machines
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Doesn't spin all the water out
sounds like the coupler that connects the motor to the transmission is going bad.  A $20 part
Mar 30, 2009 | Kenmore 24902 Top Load Washer
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 23822 Top Load Washer Logo
150 people viewed this question
Sal De
fordexpert
Robert Rankin
