Question about Verge VMP508 CD Player
No display I have power to everything and the dislay lights up but there is nothing there. No read out.
The face does not come off it just flips down. the flex conector or ribbon will break at the face plate site leaving you with part of the screen working or not at all (and the unit still works you can't see any setings), worse the eject will not work you have to reset every time you change a cd. I'm looking for the part discription and part # to order it.
Posted on May 27, 2008
Hey Guys , I was wondering if the solution given over here helped you. I am also having the same issue and my display is somewhat gone. It sometimes comes up on tapping the screen which makes me feel that the solution proposed over here could be of help.
Posted on Jul 10, 2006
I had the same problem but the radio wasn't working, only the backscreen bluelight was working. At first I didn't saw there was a fuse on the yellow cable but the problem was here, change it and it will work.
Posted on Aug 31, 2008
Sillygirl, would this fix work for a removable security front type cd/radio such as aVDO MS-4200? They are aGPS based cd/radio unit.
Cheers
Posted on Jun 23, 2008
Sillygirl; Would this fix work for a cd/radio with a removable front panel?
The iluminasion of the screen is disappering
Posted on Apr 19, 2008
I had the same cd player with the same problem when i hooked mine up too. But i used a different wire harness because it fit , but you have to use the one that comes with the dek and make sure all the wires are hooked up. and make sure that you hook them up right.
Posted on Sep 22, 2007
Ello..i have the pioneer avic x1 and the screen is gone blank...you can just make out sometimes whats on display as you can see a bit in the dark but not alot...and also you can still touch the screen and it will work.... but dont know what am pushing..i did blow in it and it worked for a day and the nest day it went the same...tried blowing in it but dont work......help!!!!!!!!!!!!
Posted on Sep 18, 2007
  • 513 Answers
The following fix worked on a different radio, hope it does the trick for you. first of all - if you're still under warranty, or have no experience with opening up elctric devices, don't touch it. take it back to the shop, or to a pro. If you paid someone to install it for you recently, then you should consult that someone. here we go - If you pull the radio from the dash, you can unbolt the four 1/4" boltson each side of the radio and the entire front panel will come off(that was the case with mine, find what works in yours). You will find a flexible ribbon connector that connects the electronics which drive the display from the rest of the radio. Take that connector and clean the contacts with some contact cleaner and a q-tip, spray some contact cleaner in the "socket" end of the connector on the radio, too. Very good chance this will cure your troubles, it cured mine. IF THIS DOES NOT WORK, then you have suffered an electronic failure (as opposed to a mechanical failure...the most common type!) and will probably have to replace the entire radio. Of course, only the front half or back half is the problem, but I doubt its economical. Good luck
Posted on Jan 23, 2006
Buttons are lock on television
hi, try this Power Button Lock
This mode locks the power of the LCD dislay in the ON position.
• Power Button Lock: Press and hold [1] and the down arrow for 10
seconds. If the power button is pressed the message Power Button Locked
will display for 5 seconds. With or without this setting, after a power failure,
your LCD dislay's power will automatically turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow again for
10 seconds. hope it helps
regards
shaun
Apr 05, 2014 | ViewSonic N3735W 37 in. LCD TV
What is combination for entering service menu on LG M1962D?
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Jan 18, 2011 | LG M1962D Monitor
Hello, I turned on my HP 1510 all in one printer: all dislay lights are turned on and the printer does not respond to any command, e.g. to all the buttons I press nothing happens. Is there a way to...
UNINSTALL UR PRINTER AND THEN REISNATLL IT BUT MAKE SURE U READ INSTALLATION INSTRUCTION IN UR BOOK......JUST GO STEP BY STEP UNTIL IT TELLS U PRINTER HAVE BEEN INSTALLED.......IT MAY TAKES SOME TIME
Nov 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
My Everstar mpm-08cr-bb4 stopped working and dislays P1
The P1 code means the lower water bowl is full.
Put a pan under it an pull the lower plug (some 10" below the upper drain plug that I hope you have a hose attached to.
Jul 07, 2009 | Heating & Cooling
No sound but all lights light up. Displays DT7000
Bonjour,
I have exactly the same problem with my DT7000. Did you find a solution to your problem?
Stephan
May 01, 2009 | Audio Players & Recorders
Display problem
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jul 30, 2008 | Nokia 6230i Cellular Phone
No display on front pannel
I had this same problem. I solved it by connecting both yellow and red power supply cable coming from player to only yellow cable from my car. There was also red wire coming from car but things didn't work that way. I can't say I knew what I was doing so try on your own risk.
Mar 10, 2008 | Sony XPLOD CDX-GT200 CD Player
Toshiba 24z37b dislay problem
check ineternal circuit of tv. may be dry soldero or any part intermiiat operation..check everything in circuit..
Oct 07, 2007 | Televison & Video
Verge VMP508 CD Player Logo
863 people viewed this question
Top Verge Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Verge Car Audio and Video Expert? Answer questions, earn points and help others
