Question about HP Photosmart C7280 Laser Printer
Ink system failure
The first time I turned on the printer, after installation, and every time (except once) since, I get the error: 'Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19a0020. Turn power off, then on again.'
I have checked documentation and cannot find this error. I have turned "on" and "off" numerous times, pulled and re-set the ink cartridges, etc. One time, for some unknown reason, the printer did print, until it went into sleep mode. That was the ONLY time it ever printed.
Any ideas on how to eliminate this problem for good?
  • Anonymous Oct 21, 2008
    still couldnt solve!!!
  • 20 Answers
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Posted on Jan 02, 2009
  • HP Master
  • 4,338 Answers
Do this: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 03, 2008
Ink system failed. Error: 0YC18a0201
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The all-in-one cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the all-in-one off.
  2. Unplug the power cord from the back of the all-in-one.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the all-in-one.
  6. Press the On button to turn the all-in-one on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the all-in-one.I hope this information be helpful. Regards
Apr 05, 2010 | HP Photosmart C6180 All-In-One InkJet...
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer error Oxc18a0001
Hi there
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure error Oxc18a0306
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Dec 11, 2008 | HP Photosmart 8250 InkJet Printer
Hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
Nov 05, 2008 | HP PhotoSmart 1215 InkJet Printer
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Ink system failure
Turning the printer on and off will not solve your problem. If you get ink system failure you most likely have air in your ink system. This will happen after months of use -every ink cartridge you reload and purge will have a little bit of air trapped in it and over time it must add up. You have to do a system reset which causes your printer to start over and do a full purge of ink through your system. This is what happens when you do your first ink system set up when you open install new ink cartridges. To do a ink system reset you must first:
1. After your printer gives you a ink system failure you will need to press and hold down ok and cancel at the same time and then press the start button once. (make sure you hold the cancel and ok down until the system shuts down and then release).
2.Now (Again) hold the cancel and ok Button down and and press the on button again -making sure to keep holding down the cancel and ok until it shuts itself down again. It will seem like it is starting up again up will then just shut off. Now once it has shut off for the second time (It is VERY important that you have a new set of ink cartridges installed before turning on the system for the second time) This is because it will do a full ink purge and rid the trapped air in the system. If you have old ink in it or almost empty it will most likely not purge enough. A new set of ink works best- You can go back to your old ink after if you like and keep the "new" set for back up when the system fails again down the road (it will fail again -this is poor designing by HP).
3.Now once you have shut down the system and loaded a fresh set of ink (all 6 of the ink cartriges) you can now press the on button (at this time you should get a reset code the come on first and the printer will run its purging of the air and new ink.
4. You might have to do this more then once to rid all the air out of the system-keep trying and after 2 -3 times it will stop giving you the ink failure. I have fixed my printer many times by this fix for many years.
Good Luck!
Sep 27, 2007 | HP Photosmart 3210 Printer
HP Photosmart C7280 Laser Printer Logo
1,031 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
