Question about Teac AG-D8900 Receiver
Protect After being in use for 15 minutes or so, my Teac receiver readout will fals "Protect" and shut down.
    Novelist:
  • 196 Answers
You may have shorted the speaker wires. Remove all wires from the output connections and make doubly sure no strands are left there. Turn volume to zero and turn the receiver on. If the problem persists, you probably fried the output stage. Have it repaired.
Posted on Jan 22, 2006
SOURCE:
TEAC NP-H750 Amplifier goes off automatically after being turned on 3 minutes before - BCO Protect on LED
The amplifier is going into protect mode to prevent damage. Obviously something is wrong and TEAC doesn't want to be bothered with finding and fixing it.
Sep 03, 2018 | Teac Audio Players & Recorders
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
The stereo plays for a few minutes and then turns itself off
hello it sound like the output transistor has blown or a capacitor has swelled up
shaun
Sep 16, 2009 | Teac AG-D8900 Receiver
Re: Denon AVR-1100 receiver Just powered it on after years of not being used, although I know it works just fine. Powers on fine, but the readout on the screen says "AUTO" (small) and "PROTECT" (large) and...
The receiver has gone into a protect mode because something is wrong and it shuts down to prevent further damage. Could be a power supply or output amp issue.
Jun 20, 2017 | Audio Players & Recorders
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Have a teac amp and dvd / cd player moved house plugged in and now amp makes clicking noise and displays "protect" ?? tried resetting as per manufacturers instructions ............still no joy ?
Protect mode happens when the amp detects a problem internally and shuts down to prevent further damage. The most common cause of this is shorted output transistors. Without takeing measuremetns inside the unit, I can not state the specific problem, but a repair for this is relatively simple. Expect a cost of $15-$40 for parts plus the local labor rate.
Dan
Mar 27, 2008 | Audio Players & Recorders
Protect keeps flashing
there is a similar problem to yours on here. also, does it take a minute to go into protect or does it happen almost immediately? i'd unplug all your speakers from the back of the receiver and turn it on, if it still goes into protect it sounds like an internal problem which has been addressed. look at this for internal problems; http://www.fixya.com/support/t245043-teac_stereo_receiver_model_agv8520
Jan 20, 2008 | Teac AG-V8060 Receiver
Teac g-v8520 protect problem
Check the thermal sensor, TH1. This causes the unit to go into protect, it is a common failure part on this model.
Oct 26, 2007 | Teac AG-D8900 Receiver
Teac AG-D8900 Receiver Logo
290 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
