Question about Electrolux Washing Machines
AEG Washing Machine OKO Lavamat 62310 Turned on after finishing last wash and blew power fuse. Will not switch on now.
5 Suggested Answers
  • 1294 Answers
SOURCE: aeg lavamat 538
Your door will not open if there is water still in the machine. Try "spin only". If this fails, get a bucket, remove your outlet tube from the wall drain, put into bucket. Wall plug off first. After all the water is drained try the door, do not force it.
Then check your outlet filter; the water does not go thru for there may be a block in your filter, or tube from the tub to drain area. Or finally in your pump. Dont forget to refix drain pipe in wall in exact position.
And rate me pl.
Posted on Dec 01, 2007
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: AEG Oko-lavamat 538 manual
www.manualshark.org/manualshark/files/5/pdf_10471.pdf
Posted on Dec 10, 2008
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
SOURCE: AEG OKO LAVAMAT
- Turn Off - Press down Prewash and Soaking together. Keep them held down. - Slowly turn the knob clockwise to Gentle Spin - This should reset the machine
If you get a beep instead of a reset, there is a problem. - Keep the two buttons held down. - Slowly turn the know anti-clockwise to Wool 40 degrees - It should now give you an Error Code. - Google for the manual, which will tell you what the error code means
Posted on Sep 06, 2009
Where is the filter for die AEG lavamat 538 washing machine and how do you clean it?
The only filter/screen I am familiar with is the one in the hoses the supply hot and cold water to your machine. They should be checked once in a while but I have never found much in them.
However, the manual for your machine is located here:
AEG OKO LAVAMAT 538 Operating Instructions Manual
Best wishes,
Joe
Aug 24, 2016 | AEG Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
Hi can anyone help me please im looking for a user manual for an AEG oko lavamat 75620 washing machine
do google search for "user manual AEG oko lavamat 75620" on page 2 about 4th down you will see a pdf manual for your model ( it's the "update" model but they are virtually identical to use ) don't download straight away it's foreign but don't despair click the option Translate this page and you'll then download an english version of the standard commonly experienced when Nigerian or Ugandan ex govt ministers let you know, via email, of an opportunity to help them smuggle millions out of their respective countries. never-the-less you will be able to run your machine from it.
Mar 17, 2013 | AEG Washing Machines
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
The machine dont start, nothing appen when connect on
go in contact wit EG customer service or the store u bought the washing machine and tell them ur problem,,,
make sure u have power on ur power outlet and it is switched on,,,,,
Mar 14, 2009 | Washing Machines
AEG oko-lavamat 72630 update
It is a communication problem between the circuit boards inside the machine. It might be as simple as unplugging and replacing the wires, or you may indeed require a new circuit board.
Aug 05, 2008 | AEG Lavamat 72640 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
230 people viewed this question
Top Electrolux Washing Machines Experts
Electrolux
Electrolux
Tim Whalen
Chris Hall
Chris Hall
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
