Question about Ovens
Oven not working
Oven was on, had apower cut and now there is power restored, reset clock/timer. But oven fan nad element not working, no illumination of the temperatures on oven dial
  • JuneauMom Sep 07, 2008
    we have same problem -- power cut off then when back on ovens do not work -- inside lights work but neither oven will come on. We have "flipped" the breaker but nothing changes.
    President:
  • 1,462 Answers
I think both of you have not set the clock correctly and oven is on automatic. get the book out and try again
Posted on Sep 07, 2008
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 | Ovens
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
The oven tripped the main fuse switch to the house while on and when i restored power the clock on the oven came on but nothing else works no grill, oven, fan or lights ???
you have to set the clock befire anything works .if you have done that its could be that the element has failed and the fault current has damaged any of the contacts in the circuit which can be themostat ,timer contact thermal cut out contacts. failure of the timer contacts would leave nothing working
Aug 04, 2010 | Baumatic B187 Stainless Steel Electric...
Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
Feb 02, 2010 | Belling XOU592 / XOU593 Electric Double...
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Oven elements will not heat
theres a thermostat on the back wall that problaby blew out as a result of surge,its wired in line with both bake andbroil element
Feb 24, 2008 | Whirlpool GBS277PDS Electric Single Oven
Ovens Logo
212 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
