Nokia 6560 Cellular Phone
Problem for Nokia 6560
Won't charge
By Guest on Jan 22, 2006
Won't recharge. Purchased new battery - drained it. Cleaned connection - didn't work either. Any ideas?
Same Problem
Nov 28, 2007
-   i need to know how to put the SIM card in the phone-   freqbeatz
Best Solution
posted on Aug 10, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Just clean the connectors and all will be fine
Solution #2
posted on Mar 22, 2006
Very Helpful)
Caroline
Rank: Apprentice
Rating: 95%, 2 votes
I fixed a similar problem with my K750i (3 month old battery would be drained every 8 hours or so) by downloading and installing the latest firmware, using Sony's own 'Sony Update Service? software, which you can download from their website.
You rated this solution as "Very Helpful".
Solution #3
posted on Jun 22, 2006
Somewhat Helpful)
sibir
Rank: Apprentice
Rating: 78%, 2 votes
I agree with "Silly girl", I had exactly that problem, first it charged intermittantly (I was suspecting a bad battery) and then it stopped all together.
The connector is surface mount, i.e. soldered to the surface of the PCB.
Open your phone (4 torx screws) so you can see the connecgtor legs on the PCB, plug in your charger and wiggle. In my case one of the 3 legs became loose and I could see it move.
I was able to solder it back on.
You rated this solution as "Somewhat Helpful".
Solution #4
posted on Jan 22, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3624 votes
If you tried with a new bat and no dice, try a different charger as well (if you decide on buying instead of borrowing its a cheaper option for a first check ).
Still no joy? Then my guess is that it?s the connector in the phone.
good luck, don't break any legs :]
Solution #5
posted on May 02, 2008
Not Rated)
kalansing
Rank: Wiz
Rating: 77%, 73 votes
swap the battery from another ericsson phone, a t39, r520, t29, etc.. just to check if the your t28 is alive. good luck
Was this helpful?
Yes
No
Solution #6
posted on Jan 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I've had the same problem and have come to the conclusion that the life of a cellular phone is determined by the availability of fresh or recently manufactured batteries.
Acording to Wikipedia, Litium Ion batteries have a limited storage life. Idealy they should be stored in refrigerated conditions at 40% charge, however If they are kept at room temperature, then two years is about the longest time they can be stored before being un useable. Very fiew have a manufacturing date on them, so given the age of this phone, the likelyhood of picking up a 'dud' is very high. The dealers aren't aware of this & will sell you old stock at full retail prices too!
Pity though since this was a lovely model. The manufacturers should have an obligation to supply things like batteries for a longer time after a model is discontinued. Even the pirate parts suppliers only seem to make batteries for current or large volume sellers.
Solution #7
posted on Jun 26, 2007
Not Rated)
phoinix
Rank: Wiz
Rating: 78%, 61 votes
m8
if you cant figure it out send it to these guys http://www.mobilephoneservicecentre.co.u... they check it for you for free and prob fix it for you for next to nothing
hope they can help
Comments:
Jun 26, 2007
- m8
i have had similer problms in the past and changing battery and charger havent helpd
Was this helpful?
Yes
No
Popular Solutions for Nokia 6560 Cellular Phone
Questions and Unsolved Problems for Nokia 6560 Cellular Phone
Do you recommend Nokia 6560?
Answer
Answer
i cant recieve calls or make any calls from this k800i i can send text and recieve text and recieve... (More)
Answer
lost contact info. when i factory restored my phone,,, at&t, samsung 737.... need info... (More)
Answer
Nokia 6560 slide has stopped working. turned itself off. I presumed it was battery, so recharged but... (More)
Answer
i have forgot my security code for my phone and it will now not unlock, please can you help m?
Answer
worked fine, till my boyfriend put a chaep battery into it and it died, I've been told there are was... (More)
Describe your Cellular Phones problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
in Newport, KY
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
