Loose agitator on Whirlpool Ultima Care II washer
Agitator seems loose. Machine working fine, but agitator makes loud noise when running. How can I tighten it up? I think my son got some heavy blankets wrapped around it during a wash.
  • Anonymous Mar 27, 2014
    My Whirlpool Ultimate Care Imperial LSQ9244EQ0 shakes violently on the spin cycle and the adjitator seems to be too loose. I have tried tightening the bolt in the adgitator (that tall thing in the middle) but it wont tighten any more.
  • 958 Answers
It could have stripped the spline on the plastic agitator. there is a bolt at the middle of the agitator and you can access that thru the top . remove the top cover and you can remove the bolt using a deep socket.
once you remove the agitator you can look at the dog agitator. these a 4 pcs plastics that works like a one way wrench.
be careful on the location, they are very hard to put back.
check also the spline on the inner part of the plastic assembly.
they do get stripped.
if they are, replace the whole agitator.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
Agitator not working making loud noise when washing or spinning out. water drains but clothes are still soaking wet
can you have the door open all the way to see if the agitator spines all by its self or you can held the agitator with your hand if you can then you need a new agitator dogs part number 80040
the agitator dogs look like this pic below
Jan 22, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ult care II (plus) washer, agitator makes noise
yes, sounds like your agitator dogs are broken, four beige teeth inside top of agitator part only roughly 4.99 to 29.99 and labor 65.00 - 95 labor depending were u live and who u use. thank you
allbrandsappliancerepair.com
Sep 23, 2009 | Whirlpool Washing Machines
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My ultimate care II washer spin cycle stopped working. The motor makes a loud noise. The agitator no longer turns.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Replace the direct drive coupling between the motor and transmission.
Jun 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud while agitating
CHECK COUP-LER BETWEEN MOTOR AND GEARBOX.if coupler good,then gearbox bad.
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer Mod# TWAS750PQO, Ser# CR3520005
is it possible that the washer was overloaded? if so the agitator has little plastic "gears" that move the agitator one way only, they could have made the sound.
you can also check under the washer to see if anything (like a coat-hanger or something) is interfering with moving parts of the washer
Jun 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
Feb 09, 2008 | Washing Machines
Washing Machines Logo
342 people viewed this question
Top Washing Machines Experts
