Question about Kenmore 24032\24036 Top Load Washer
Water runs during spin cycle
Water won't turn off during the spin cycle
  • 1 more comment
  • Anonymous Sep 15, 2008
    I have same problem with model 24962. The water emptys at the end of the rinse cycle, then runs in at the spin cycle. This occurs at anyone of the four spin timer positions
  • ksjak Sep 18, 2008
    Same problem , just started last night, water runsduring spin, anyone have any ideas?
  • monica2899 Oct 27, 2008
    I have the same problem with my GE washer. It works fine except that water starts running in during the sping cycle, then continues to run in even after the washer turns itself off (it never actually overflows, just fills to the top). Then I can only turn the water off by the wall valves, and have to put it back on the spin cycle to get the water out. Has anyone solved this problem?
    Novelist:
    Champion:
  • 261 Answers
I would suspect that you timer is shot, only during spin? During the day when water use is high does it leak then?
Posted on Oct 08, 2008
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
My whirlpool machine does not spin properly and there is always water left after the spin cycle, when its turned on it will stop after spin cycle like its finished but there is still a lot of water left in...
hi, it sounds like one of two possibilties, will try and help out. The first thing to check is whether the water/drain pump is actually working fine, i think it blocked. Secondly the pump may also be overheating and malfunctioning during the cyle, run it without clothes and check the flow of the drain during the drain/spin cycle and take it from there.
Jun 14, 2011 | Whirlpool Washing Machines
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Dec 22, 2009 | Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
118 people viewed this question
Sal De
fordexpert
Robert Rankin
