Pc starts to boot then hangs at 'Intel inside' logo. Faint noise from hard drive but nothing else happens. I've heard the occasional ominous clunking noise from inside too, before & after it developed the fault.
  • fredamike Sep 07, 2008
    Thank you. I had a horrible feeling that might be the case. PC is out of warranty and I'm a PC dummy so will have to find a PC pro to fix it for me!
  • 3,940 Answers
Most likely you are experiencing a hard drive failure.  The Click of Death is normally a good indicator.
Most likely a hard drive will resolve your problem.  If the system is under warranty, contact the vendor.  If not, you can buy a replacement HDD normally for less than $100
One source I like is http://www.newegg.com
Posted on Sep 07, 2008
On startup os logo hangs up
Is not compatible with your device
Mar 20, 2013 | HP Compaq 6730b Notebook
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
Feb 14, 2012 | Intel D865GSA (BOXD865GSAL) Motherboard
I have a TOSHIBA Satellite A660 and occasionally, from the bottom right hand corner, (under the number pad), there'll be this 'clicking noise'. It kind of sounds like something sliding and then...
This is not uncommon to hear and usually nothing to worry about, but for piece of mind you can purchase an external hard drive to back up your files.
May 18, 2011 | Computers & Internet
When booting, the system hangs at Windows XP logo. It does the same when booting (or trying to boot) into safe mode. What could be the problem and how do I resolve it? I tried to use the Windows XP CD to...
You can access the BIOS usually by pressing "esc", "F1", "F8", or "F12". One of those buttons
should work.
As for the hang up at the logo, it sounds like your hard drive might have crashed. The same thing
happened to me on my Vaio.
Feb 09, 2011 | Toshiba Portege M700-S7002 Tablet PC
Thinkpad r50 does not start (repeated clicks could be heard from somewhere inside) unless I press on certain spot at the motherboard (on top of cpu fan). once I've managed it to boot up it hangs if being...
Any metalic sounds or clicking noise from the hard drive when booting up is an indication of a faulty hard drive, especially when Windows does not start up.
If it does start up but hangs easily then it has not failed completely. I suggest that you backup you data
To test the hard drive, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port, it this computer cannot detect it as an external hard disk and cannot open the folders and files then it is faulty.
Replace the faulty hard drive in the Thinkpad and install Windows to get a working laptop.
Aug 01, 2009 | IBM ThinkPad R50e Notebook
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
Boot Problems
PXE means it will only boot while connected to the network,
You need to change the bois From network boot to Hard drive boot.
The system doesn't see a hard drive inside,
it thinks it is booting from the network only,
it boots to a server like this.
It is called a dumb terminal
Richard.
Apr 26, 2009 | Computers & Internet
Faint noise on booting.
Try this remove side cover and boot computer listen for any extra noise fan etc. also by power supply
As I think you have a bad bearing in a fan
To temp fix it
remove paper cover over center of fan and put a small and I mean small drop of light machine oil on bearing then replace paper cover.
check if this stops the noise if it does you know which fan to replace.
If it is power supply fan and if you think yourself capable remove fan and do the same to it
Oct 13, 2008 | Intel Motherboard
Occasional BOOT hang
Try using the event viewer and see if it comes up with anything
How To Use the Event Viewer Applet
http://www.bleepingcomputer.com/forums/topic40108.html
Jan 02, 2008 | ASUS P4S800D-X Motherboard
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
