Question about Philips 50PF7320A 50 in. Plasma HDTV
Philips 50pf7320 plasma
Any body got any good settings for my tv before i get an expert in to do it?
cheers
  • 2,071 Answers
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
DON'T FORGET TO RATE;
Posted on Sep 07, 2008
My phillips tv 50 plasma hd can't show picture
Problem is in either power supply or - my bet - the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
hope that help out......
Jan 18, 2011 | Philips 50PF7320 50 in. HDTV-Ready Plasma...
Hi. I have a Philips Plasma TV model no. 50pf7320, and I have not been able to track down the problem which goes as this: after replacing four 58" z. diodes on the Y "Sose" board, together with 2 fuses,...
You have a bad lower Y-DRV (or buffer, which ever you like to call it). If you want, you can change the IC itself... but they are usually smothered in hot glue. This board attaches to the Y-SUS that you were working on. It is common for the Buffers to knock out the Sustain board. I hope this was helpful, best wishes.
Oct 06, 2010 | Televison & Video
When I turn my tv on it takes 10 minutes for it to turn on? A red light flashes? What is that?
That usually indicates a lamp is failing inside the unit and needs some fairly major repairs. If it is still under warranty, or if you want to deal with Philips directly, please contact them and find out about repairs, their number is 1-866-310-0787
Sep 13, 2010 | Philips 42PF7321 42 in. Plasma HDTV
Phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem. This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Aug 03, 2009 | Philips 42PF9630A 42 in. Plasma Television
Black Vertical strie on plasma TV
I think you have a frame fault on the tv. If you are capable check the picture frame board first. If not find a competant technician. Good luck.
Oct 02, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 50" plasma
Press the volume and channel button at the same time on the tv.
Aug 19, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips tv error code
1 long and 4 short blinks for this model is specific to class d audio amplifier on small signal board. if it is intermittent where this sometimes happens and you can unplug and replug and power back on would be related to the firmware version but if version is correct you would still need to replace ssb
Aug 17, 2008 | Philips 50PF9830A 50 in. Plasma HDTV
Phillips plasma 50pf7320
I have a 50 inch phillips plasma and the pixtals are taking over and color is dark the amblight is very dim,
Jun 25, 2008 | Televison & Video
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 50PF7320A 50 in. Plasma HDTV Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
