Question about Jensen VM9410 Car DVD Player
No sound with discs playing
My tv is hooked up correctly, and the is music when the radio is set on tuner, but when there is a disc in the player wether it is a cd or dvd, the is no sound.
    Novelist:
  • 196 Answers
There should be some sort of outboard amplifier. Mine had an amp at each speaker, and also a receiver mounted behind the passenger seat. Could it be that the power antenna lead from your headunit is connected to the amp turn-on lead? That way, when the radio is playing, the antenna lead is powered and thus the amps are too, whereas when the CD is playing, the antenna lead would not be powered and thus no sound. Try reversing these two wires (Power antenna and amplifier turn-on) and your CD should work.
Posted on Jan 22, 2006
I have 2 problems with my lg hb 966trw: a)
follow this steps and fix it. God bless you
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
switching regions:
    • 1
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Oct 30, 2013 | LG Televison & Video
My techwood tv will not play sound and the colour is not right. how do I fix this?
see the charts troubleshooting and fix it. God bless you
No sound
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
Try a direct connection from the DVD player to the TV set, instead of via other components.
Oct 14, 2013 | Gemini 1 Device Universal Television...
No picture, no sound
see the troubleshooting index:God bless you
No sound
Does not play disc
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | Televison & Video
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
Jul 21, 2012 | Wharfedale DVD-M3 DVD Player
My cd player will read the disc and starts playing but there is no music out of the speakers
I have the same problem, my sony explode i just hooked up will only play the radio not the CD or Aux. Like the CD Plays but no sound out of it at all.
Sep 03, 2009 | Sony Xplod CD Player w/MP3 Playback...
DVD disc reads that it is playing, but there is no
what tv connection are you using from the dvd make sure connection are fully pushed in, try another dvd player with the same tv and connections.
Aug 25, 2009 | Zenith XBR616
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
Jensen VM9410 Car DVD Player Logo
172 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
