Question about Brother NX-400
Auto threader NX Brother sewing machine. My auto threader has giving me problems with sometimes working and sometimes not. (more not). When I push down to thread it sticks and has since shortly after I got. I called where I got it and they just gave me a run around. Please help me if u can with this problem im having with it. Thanks, Joyce
  • nanatwo Sep 07, 2008
    I own the Brother NX 400 machine and has anyone out there have or had any problems with the auto threader not working right?
    Nanatwo
  • dalecar Jan 12, 2009
    I have the same problem. Periodically the needle threader just stops working! My repair center is more than an hour away and they keep the machine for weeks - it's maddening. Most of the time, they tell me there was nothing wrong with it when they tried it!!!
    Does anybody know what to do about this problem?
Check the needle length. My new needle was about 2 mm longer than the orginal which resulted in autothreader not working. I ground off difference from blunt end of new needle and autothreader now works. OR make sure you are using the correct length needle.
Posted on Nov 26, 2008
  • Brother Master
  • 5,568 Answers
The parts for any autothreader are necessarily delcate considering the nature of its task. Check (without thread) to make sure the tongue that passes through the eye of the needle isn't bent a tiny bit causing it to strike next to the ****. Have seen this more than once.
Posted on Sep 07, 2008
Cannot thread my PC 420
Try to push the lever down on a very fast and hard punch. Sometimes that is the way my machine works. Punch it!
Mar 17, 2014 | Brother PC-420
Difficult to use auto needle threading
you thread the machine the normal way, using every thread guide, and if the automatic theader works it will thread the needle,
if the auto threader doesn't work, then it needs to be checked.
also make sure the needle is turned the correct way and inserted correctly into the needle holder.
Mar 06, 2014 | Brother 50-Stitch Limited Edition Project...
Auto threader wont come all the way down...makes a poping noise
Personally, I wouldn't bother to fix it. Take a sharp pair of scissors and trim the end of the top thread at an angle and poke it through the eye of the needle. Autothreaders are usually the first thing to break.
Jan 25, 2014 | Brother Sewing Machines
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
My auto thread component is not egaging the thread down to the needle.
Need more information. Is the auto thread component going down to the needle? Is
it missing the needle hole? If this is the problem, make sure that the needle position is in the correct position by pushing the needle position button. This will bring the needle to correct height for the thread to be inserted. I had a problem similar and it was because the needle was not in the correct position. When using the thread insertion press it slowly and watch to see where the insertion part is going.
Oct 29, 2009 | Brother CS-8150 Computerized Sewing...
Brother CS-80 will not always thread the needle when I depress the thread cannister.
I get this problem too. I found that it might be because I've moved the wheel while sewing previously and the needle doesn't go back to where it's supposed to be to be auto threaded correctly. To solve it, I just push the canister down until the threading parts are lowered. Once I see where the threader is positioned, I use the wheel to adjust the needle height to where the threader is, then I push the canister down all the way, and the needle is threaded. Hope it works for you!
Feb 22, 2009 | Brother CS-80
How to use automatic threader on the pe180d embroidery machine
make sure needle is in the highest position before you thread
mary h
Jan 06, 2009 | Brother Disney PE-180D Computerized Sewing...
Brother se 270d sewing machine
The auto threader attachment has fallen off.
Nov 24, 2007 | Yamata FY101-1A
Automatic threader mechanism keeps sticking and a part falls off
These machines are nothing but TROUBLE and always will be. Get rid of it. Save yourself much time and frustration.
Apr 22, 2007 | Brother SE-270D Computerized Sewing...
Brother NX-400 Logo
352 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
