Question about Frigidaire FAC124 wall/Window Air Conditioner
Fidgerdare electrtolux air conditioner
Good morning:
Our Ac wall unit is about 3 years old. Noticed that the coils and the insie of the unit is iced up and causing the ac to leak inside the house.riella
It is cooling, but need to make sure we are not in any danger if still operating it.
Thank you
Gab
  • justsundays Sep 07, 2008
    Thank you drcool. You were helpful. We were going out to buy a new one. As our older modls nver had this issues.
    have agood day
  • 958 Answers
Have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
I use my kenmore single room air conditioner all night, in the morning the coils are all froze up? is that normal? The fan is working & I hear the compressor working. Maybe something is going out? it's...
Please check the filter. The filter is located behind the front grill. If there is a lot of dust & dirt on the filter, it will reduce the airflow over the coil significantly - causing freeze ups. A filter that is missing will require a thorough cleaning of the coils to remove the dust and dirt, then installing a replacement filter. There are products sold at hardware stores, home improvement centers, etc. designed specifically to clean these coils easily. You should be able to get a replacement filter for the AC from Sears.
If the filter is present and clean - there could be a problem with the refrigerant charge, or other problem. Many times, an AC units of this small size, it is cheaper to buy new than invest in repairing a 3 year old unit.
Please rate this reply if helpful - good luck!
Aug 25, 2010 | Kenmore Single Room Air Conditioner
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Coil and fins start ice up
The fins are dirty. They need to be washed every year or two with an acid based cleaner. They MUST be rinsed completely.
Jul 21, 2009 | Carrier 38CKC030 Air Conditioner
Not blowing cool air on my Ruud, 18 years old, outside unit.
If you have ice on the Line you are iced up. If coil is iced no air can get thru. Now First. Turn of ac and turn fan to on posotion. That will thaw unit. Let it run 45 minutes. That should do it. If the fan is not running you amy have a bad fan relay. One of the reason iced up unit is dirty evap, coil inside. Try to thaw it out first. You can clean the coil with a stool brush. Does not damage the coils. Good luck
Jun 07, 2009 | Ruud UBHC Air Conditioner
AC Problems
1 and 2 there two type of motor 1 has lubricating acces this youshould lubicate the other no noacces. but commonly if you lubricate and still noisy you change the bearings qty2 or sleeves qty2
2- common cause of ice
- thermostat on min setting
- thermostat defective
-air filter is very dirty
-evaporator is cloged no air pass throu
- loss of freon ( a/c is leaking)
Apr 30, 2009 | Friedrich CP06C10 Wall/Window Air...
Goodman CKL60-1L
Four things cause icing up:
( 1 ) Is your filter clean? dirty filter blocks air flow causing iceing up. replace filter
( 2 ) Do you hear the Indoor fan running? If the fans not running the unit ices up. Check Capacitor to fan if good.
Bad fan motor... replace fan motor and cap. If both good
( 3 ) Check Air Handler evap coil if dirty and or clogged, restricts air flow causing unit to ice up. Use toilet brush to clean.
This is always a big possibility if you have pets.
( 4 ) If the above are not present then you are low on refrigerant.
Low refrigerant will cause icing up because the gas does not flash properly. This will require a service tech.
refrigerant leaks can be as simple as a loose cap on the king valve, leaking schrader core, to coil leak.
Have the service tech show you the leak. If it is in a copper line it can be fixed. If the system is over 10 years old limit the amount you want to spend. 10 years is the standard life expectantcy anymore. Good luck
May 20, 2008 | Goodman CKL60AR60 Air Conditioner
Maytag AC afternoon out to lunch
Clean the condenser coil and change the filter.
May 09, 2008 | Maytag Chassis Built-In Air Conditioner...
Ice on the coil fins of my Window AC unit......
set your unit to fan mode only, to thaw the ice, after the ice melts, look at your evaporator coil, see if its dirty, if its dirty, then you might just need a good cleaning. if the coil is clean, look at your thermostat setting. it should not be all the way cold. the compressor would run continously and it would freeze the coil. third, the refrigerant system could be partially clogged up or it lacks refrigerant. these problems initiate freezing of the coil.
Feb 18, 2008 | Carrier 52PQ307 Wall/Window Air...
Frigidaire FAC124 wall/Window Air Conditioner Logo
147 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
