Question about Zenith XBS444 System
Progressive Scan When set it on dvd the screen turns blue and it says progressive scan. I can hear the movie being played but the screen is just blue with the writing. Is there a way i can fix it?
  • 6 more comments
  • Anonymous Dec 31, 2007
    my picture is black how do i fix this problem
  • Anonymous Jan 07, 2008
    When i press home menu,GUI will appear on dvd player display,i dont know what problem .
  • Anonymous Feb 16, 2008
    The progressive scan mode is on and when I go to Setup, no menu appears, the screen stays blue with "progressive scan mode".
  • Salsarina May 08, 2008
    The previous solution offered states that I try to select "composite" instead of "component", but I can't access anything on the setup menu...it is unavailable (can't see anything).
  • Anonymous May 25, 2008
    Can't get to the Setup menu to change anything, it just stays blue with "Progressive Scan Mode" showing.
  • fhofmeister Jul 27, 2008
    get sound and no video when playing dvd
  • elvy1505 Feb 25, 2009
    Zenith XBS444 player stuck in progressive mode
  • Anonymous Apr 06, 2009
    I get sound but no video when playing dvd
    Problem Solver:
  • 16 Answers
SOLUTION #1
you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Posted on May 22, 2008
  • 513 Answers
Check for video out in the dvd setup menu, and set it for composite, It may be set for component. another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work. if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system. good luck!
Posted on Jan 22, 2006
THANK YOU so much sillygirl my parents didn't believe me when I said it was the Bose system and not the plasma TV itself so I went online for some troubleshooting and you helped us out THANKS AGAIN!!!
Posted on Sep 13, 2007
Works with remote only
Posted on May 05, 2007
4 Suggested Answers
SOURCE: Progressive scan mode will not disable
Hi, you must hold 1st remove the disc (if you have one in) then hold down the STOP which is just under the RECORD button. Hold it for about 6 to 8 seconds. That should clear it.
Good luck
trestaris
Posted on Dec 15, 2007
SOURCE: Progressive Scan Mode
good luck!
Posted on Jul 09, 2008
This happened to me & I finally found a manual online that I could download.
Here's what the manual says:
"If you set Progressive Scan to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc tray. See that "NO DISC" is displayed on the display window.
2) Press STOP and hold it for five seconds before releasing it. The video output will be restored to the standard setting and a picture will once again be visible on a conventional analog TV or monitor."
Glad I could help because this problem is very annoying!
Posted on Oct 17, 2009
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
I cant watch any dvds, it says its in progressive scan mode and the screen is blue. i can hear the movie but not see it
hi,
ur dvd is in progressive scan mode. u have to get out of that setting ,because ur TV dosen't supports the progressive scan. do the following to get out of the progressive scan mode.
1. power ON the dvd.
2. press stop button to stop any disc that is playing.
3. press stop again and hold it for five seconds.
the video out will be restored to the standard settings.
ok
Jan 13, 2011 | Zenith XBS444 System
Cannot turn off progressive scan mode on blue screen to play dvd
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
May 20, 2009 | Zenith XBV442 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
be restored to the standard setting, and a picture will once
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
DVD player
unplug it and plug it back in and press the progressive button to turn it off, should work. Yeah that blue screen sucks, i would have thought you can get to the menu no matter what but that's sanyo for you, well most other brands also...
Jul 21, 2007 | Sanyo DVW-5000 DVD Player/VCR
Progressive scan
Always state your MAKE and MODEL when asking for help with regards to any product or item.
Dec 06, 2017 | Zenith XBV613 DVD/VCR Combo
PROGRESSIVE SCAN STILL ON- BLUE SCREEN ONLY
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Zenith XBS444 System Logo
468 people viewed this question
Top Zenith Audio Players & Recorders Experts
Damen Wong
Damen Wong
Gagan Telecom
Gagan Telecom
Level 1 Expert
Steve Allison
Steve Allison
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
