Question about Dishwashers
Dishwasher not working
My dishwasher is telling me that the sink spigot is blocked. we have tried to unblock it but it is still not working. what do we do next? it keeps starting but then beeps a times and flashes when opening the door
Hi
solved the problem by emptying all nasty dirty plates out and cleaning whole dishwasher inside and out. not at all pleasant , but husband was very impressed as didnt have to call man to fix it. all well now i hope.
Posted on Sep 08, 2008
Where is the sink spigot located ? I have a fault #20 showing on the dial
That will be the drain hose connection to the sink drain pipe probably under the sink. Google sink spigot in images and you can see what it looks like. I take it it is blocked..
Jun 15, 2014 | AEG 23 in. Favorit 50750Vi Built-in...
Both draws are not drainng I thnk t my drain but not sur how get th dish waher out
if its both draws that arnt draining it is most probably going to be a blocked drain spiggot, its highly unlikley that both drain motors died at the same time, look under your sink where the drain hose attaches to the little drain spigot that comes off the pipe work (this is assuming that's how you have it setup as most people do) remove the drain hose and shove a screw driver down the spigot coming off your sink pipework to dislodge any gunk or seeds that may be stuck in there, also ensure the filters in the bottom of both draws are clean , hope this helps
Nov 05, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Message on Model DWU9961 - Blocked Drain How do I
Hi wait a moment pls your request is been proceeding..
Jan 17, 2011 | Maytag Dishwasher
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
Water left in the dishwasher after the cycle is complete
Look under the sink to where the drain hose goes to. Take the hose off the spigot and make sure the hole is clear and not blocked with grease.
Jeff
Feb 25, 2010 | Whirlpool Dishwashers
I have an Miele Optima Series HG03 dishwasher. The dishwasher stops after a minute and the intkae/drain error flashes. I tried everything in the manaual but there is nothing blocking the drain or intake...
hi,
try checking the spigot under the sink as quite often the hole has not been opened up enough and there is a shoulder for food to jam up against causing a blockage. Remove the drain hose and have a look in the hole of the u bend.
If ok remove the filter in the base of the unit and remove the non return valve and make sure the drain pump can turn and there is not anything blocking it.
Dec 28, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
WHAT IS F11 ERROR MIELE DISHASHER G 1232 SC
hi
this is a drain fault. you will probably find the drain spigot under the sink is blocked where the drain hose connects.
Dec 13, 2009 | Miele G892SC SS Dishwasher
Miele G858SCVi Plus dishwasher intake drain button is flashing and washer will not fill with water. We had a pluged drain and tried to use a plunger on it and water backed up into dishwasher. ...now it...
hi,
the unit will not fill with water until it will drain as it needs to complete the drain function before it can move onto the next step.
make sure the non return valve under the filter is properly fitted in the sump of the unit. then check the drain spigot under the sink where the drain hose connects to the sink u bend. This is the most common causes of a blocked drain.
Nov 28, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Drainage blocked on Whirlpool ADG 450 slimline inbuilt dishwasher, have taken out filter and cleaned it. Still blocked.
two things to check
if drain is plumbed nito a spigot on the sink trap, check that ther spigot and drain hose are not blocked - this is very common
also see if you can get to the drain pump and check there is nothing jamming the impellor. also if you have access to a multimeter, check if the drain pump is powered up
Sep 06, 2008 | Whirlpool Dishwashers
Brand new Miele 2170/2180 dishwasher. First time we try to use it, it stops after a few minutes, the warning beep beeps incessantly, and all of the program lights are flashing. According to the manual,...
it is just possible you have a problem with the drain.
if you plumbed the drain to a spigot on the sink trap, did you make sure the spigot is not blanked? the sink spigot will be blanked if it has not been used before to stop water from the sink coming out.
just a guess but worth checking. also check drain hose not kinked
Jul 05, 2008 | Miele Dishwashers
Dishwashers Logo
124 people viewed this question
Top Dishwashers Experts
Owen Barnes
