Question about Epson Stylus CX6600 All-In-One InkJet Printer
The Epson cx6600 scanner
How long can i scan ?the service life of an scanner is about ..?? how many times can i scan... without breaking something because of usage tell please i have many albums with color photo and i wanna scan them and put them on pc and i don't wanna destroy the machine
  • 928 Answers
The service life of a device also called a service cycle can amount to thousands of hours. So go ahead and scan them all, I doubt that you would scan enough to render the unit defective but if you are using a new unit dont worry since it is still under warranty. You can always have the store or the manufacturer replace it. Also, as long as you put the scanner on a stable and level base then there should not be a probelm. Be careful as well when moving the scanner from place to place use the lock under the scanner if you will move it
Message if you need further assistance.
Posted on Sep 07, 2008
Epson Stylus CX6600 wont power up/scan light turns on then goes off.
this may help...
Check that all the access doors and compartments are closed correctly.
Check paper isn't jammed.
Take out the all the ink cartilages and reset them in correctly
Make sure the rollers are set in place correctly, (if there removable)
Hope this helps a bit
Feb 09, 2014 | Epson Stylus CX6600 All-In-One InkJet...
Error component life
printer counter must have reached its limits. you can find a resetter tool online for this brother printer cartridges
Nov 12, 2011 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600. The printer runs like it is printing, but no ink ends up on the page. This has been true for weeks, such that I have not been able to print or copy at all during that time. I have...
Dear friend,
If you left the printer idle for long time without switching it ON some more days the ink will get dry.So after trying to take print, the liquid ink won't flow through the micro head nozzles.Apart from this ,the head also contains some circutary problem,or it even be solved by just pushing it with liquid(only avail at service centrres).So better to service the printer in nearest service centre.
Mar 07, 2011 | Epson Stylus CX6600 All-In-One InkJet...
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
My computer does not recognize my scanner
Feb 18, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Download the Reference guide for your machine from th eEpson web site. It will inform you what you need to do to complete the scanning options. you can also download the Epson Scan utility to help with scanning to email etc.
Jun 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Service required error
Hi Cath.
Not sure why you would need the R260 service utility when your printer is the CX6600 but I'll answer both questions and hopefully you'll get everything you need.
The CX6600 problem is a relatively easy fix thanks to an article I wrote after fixing up one of these for my wife a few years ago. It includes information on resetting the protection (waste-ink) counter as well as redirecting the waste ink flow so that should cover that side of things.
Right... as to the R260.. You can reset the waste ink counter on that printer using the IPR_A10 utility from Epson.. Information about the utility and links for download are provided on
Hope that solves the issues you're having...
Apr 15, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Film viewing and scanning
Sorry, but you won't be able to do that with a CX6600. In order to scan film negatives, you need a printer that includes a transparency unit in the lid, that is, a panel that lights the film from behind. Also, the CX6600's scan resolution wasn't designed for detailed film scans. Try the online Epson Store at where you can often find good deals on refurbished stand-alone scanners with transparency units.
Jan 21, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Unable to write to file
I had the same problem and fixed mine without re installation. Even though the error does not indicate it very well, the application could not write to the destination. The EPSON Scan application has a destination in two places. One under configuration, in my case, correct. However, a more buried location, next to the Scan button, press the arrow to edit more settings. There, you will find another destination, in my case, incorrect ( a folder that did not exist). Change the setting to a folder that does exist, it should work. Check out my fix here, detailed with pictures. Thank you. Hope this helps someone.
Nov 29, 2007 | Epson Perfection 4990 Flatbed Scanner
My Epson Styluss CX6600 won't charge
This may be very simple. Turn the unit off and lift up the top. On the forward side of the unit you will find a little 'slider switch'. This is the scanner unlock - toggle the switch back and forth several times and leave in the unlock position. Turn on the printer and all will be well.
Aug 26, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
