Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint dishwasher df 62
Water does not appear to be getting into the dishwasher
could it be the water inlet valve?
and how do i test it?
  • 943 Answers
Hi if you have a volt meter you can check the voltage at the valve. but the water valves burn out on the all the time so i would replace the valve. thanks the appliance doc
Posted on Oct 14, 2008
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
Water Inlet Valve
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 03, 2011 | Dishwashers
Dishes not coming clean
Check water inlet valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
How to test a dishwasher water inlet valve.
How to replace a dishwasher water inlet valve.
May 26, 2011 | Maytag Dishwashers
Hotpoint dwg60 does not fill with water
If the water overflow circuit has been triggered then it can lock the inlet valve. Check if the float device at the base of dishwasher is moving up and down when pressed.
Alternatively, the inlet valve may be faulty.
Jan 01, 2011 | Hotpoint 24 in. DF55 Free-standing...
Dishwasher wont take in water but pump is working, had side off and checked in coming supply. could it be the electronic valve on the supply in?
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Sep 24, 2010 | Hotpoint 24 in. DF55 Free-standing...
Pumps water out but not water in to start cycle
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models.
Apr 07, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
The Hotpoint Aquarius DF62 Dishwasher detergent draw has come off, how do you refit and which spring goes where
Help! how to you put the spring back on the detergent compartment on Hotpoint Aquarius DF 62, any help would be appreciaed,,,,
Oct 05, 2009 | Dishwashers
No water getting in. main water line is ok and tested
Test the inlet valve and the water level switch.
The inlet valve can be tested reading continuity on valve solenoid contacts, check also the water level switch actuated by a floating sensor.
If they are ok then the problem is usually the timer control board. Testing this part is more complicate and is done reading voltages.
Always keep your appliance unplugged when you DIY.
Regards.
Jul 14, 2009 | Hotpoint Dishwashers
Hotpoint DF31 Dishwasher
You need a new inlet valve. Axcessed through bottom panels below door there are screws in the four corners of the upper one. Inlet valve is where the water line meets a plastic body with wires going to it. www3.sears.com for parts.
Oct 05, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
255 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
