Question about Panasonic Lumix DMC-FX8 Digital Camera
Buttons not working.
I don't recall dropping my camera, but the buttons aren't working now. i can press them (except the right-most one for flash), but nothing happens when i press anything. i can't take any pictures either. when i switch on the camera in display mode, it shows the last picture i took, this doesn't change, but the numbers keep changing. i was just wondering if anyone has some idea as to what this problem is caused by? my international warranty is limited and i don't want to repair it where i am now if it's going to be too expensive. i'd rather get it repaired for much less when i get back home in may. thanks.
  • 513 Answers
Try resetting before sending for repair. remove all batteries, cards,cables, etc.; let it sit 18 to 24 hours. let battery exhaust and fully charge it again. try getting an estimate from the local shop, or wait to get back home to a place you trust. good luck
Posted on Jan 22, 2006
T3 built in flash won't pop up. Says I have an external flash attached, but I don't.
There is a small flat leaf spring under the hot shoe rail where an eternal flash slides in. If an external flash is mounted the leaf spring is pressed against a small button telling the camera that there is an external flash mounted. Take a toothpick and rub under the hot shoe rail gently to more the leaf spring or unjam the leaf spring. You may even see the button depressed, poke at it a time or two with a toothpick, even a drop of rubbing alcohol may unstick this button if a sticky beverage sprayed on it.
Dec 25, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
How do I turn on the flash? I tried to buy a really simple camera and there's just too much 'stuff' on it. everything seems to be ok, just can't figure out how to make the flash work. ...
Easy. When the camera is in normal shooting mode, press the up button (marked with the symbol of a lightning bolt) until the symbol of a crossed out lightning bolt near the top left of the screen turns to an uncrossed lightning bolt symbol. that's it.
extra tips-
  • if you keep pressing the up button until the lightning bolt symbol has a letter A next to it, the camera will fire the flash only when it thinks it is necessary. this will keep your flash from firing in bright light and therefore save battery charge.
  • remember when you flipped through your math textbook in the first grade and it had "too much stuff on it"? you think its too much because you aren't used to it. don't be afraid to mess with the settings in order to learn how to use your camera best; you can never permanently damage a camera in changing its settings. the worst that could ever happen is losing all the photos in memory. if anything else goes wrong, you can always return the settings to what they were when you bought the cam in a few button presses (refer to the manual).
good luck and happy shooting!
Sep 04, 2011 | Vivitar ViviCam 8018 Digital Camera
My daughter can't take pictures outside as the flash goes off and it just gives a white picture as it's too bright, what can I do?
1. You could try pressing the reset button. 2. You could press the "delete" button to change the flash mode when you first turn the camera on. 3.=Please check your flash setting to make sure that you don’t have the camera on forced flash mode (indicated by the lightning bolt with the plus sign in the upper right corner).
Using this setting in strong lighting conditions would result in a picture with too much
light.
4. If all else fails, you can call 1-800-521-2010
Aug 17, 2010 | Vtech Kidizoom Digital Camera
My camera has never been dropped why isn't my flash working?
Hi jlapread
If your camera is giving you a `E91` error on screen it could be a faulty flash module and need replacing at a Sony Service Center. Contact your dealer for info.
But, before you do that try steps 1 and 2 below.
Here is some things you can try:
1. If it is only a setting you can select the `green` camera for auto shooting and then press the `UP arrow key until the flash sign is shown on the screen. The screen will also say `Flash On`. Take a picture to see if it works.
If not proceed to `2` below.
2. Press the `Menu` button.
First select the `Green` camera on the selection knob.
Scroll with the right arrow to the little toolbox picture.
Once in the setup menu scroll down to the toolbox picture with a 1 under neath.
Press the right arrow arrow and then scroll to the `Intialize` option.
Press the right button and select `OK`.
Press the middle button on the arrow selector.
Camera now wants to know if you are sure, select ok.
You will now have to enter the date again and setup any `Program` settings you might want on the camera.
Now take the camera into a dark room - as it is now on `Flash Auto` and test to see if the flash works.
If none of these helped you, you can take the camera to a repair agent and get it fixed. I have replaced numerous of the flash modules at approximately a quarter of the cost of the camera.
Hope this information helps you.
Good luck
Jan 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Canon a 620 flash
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Apr 03, 2008 | Canon PowerShot A620 Digital Camera
Won't take picture when flash is turned on
Charging of the flash may be overpowering the batteries that you're using. Are you using alkaline batteries? If so, recommend instead trying rechargeable NiMH batteries rated at least 2500mah to see if the problem still exists.
Feb 27, 2008 | Canon PowerShot A530 Digital Camera
The flash on my camera is not working!!!!
If the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Hope this one helps.
Jan 12, 2008 | Samsung Digimax S630 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Flash doesnt work
There is a small battery (or large capacitor) inside your camera that stores a charge for when the flash fires. If you dropped your camera and hit the right spot, this battery may have been bumped out of position. A solution would be to open up your camera to see, but this is obviously risky and can void a warranty if you still have one. If you do choose to look inside, be sure to not tear any gentle wiring as this can ruin your camera for good (I know because it's happened to me).
Jul 13, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Panasonic Lumix DMC-FX8 Digital Camera Logo
200 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
