Question about Lands Phones
Magma 200 answering machine - Lands Phones
  • geoffshing May 05, 2009
    I have a one tel, magma 200 phone and do not know how to record an answerphone message, with no instructions I cannot figure i out. Any help? Thanks
How do i turn off the answer phone, it only rings 2 times
Posted on Dec 27, 2009
  • khanhosen1 Apr 08, 2011
    i have same problem "it only rings 2 times, then goes to answer matchine "
    how to change the settings?
Why do volcanos erupt
Volcanoes erupt because of density and pressure. The lower density of the magma relative to the surrounding rocks causes it to rise (like air bubbles in syrup). It will rise to the surface or to a depth that is determined by the density of the magma and the weight of the rocks above it. As the magma rises, bubbles start to form from the gas dissolved in the magma. The gas bubbles exert tremendous pressure. This pressure helps to bring the magma to the surface and forces it in the air, sometimes to great heights.
Jun 11, 2017 | Computers & Internet
Im looking for manual for a one tel magma 100.
You can try to fill up this form and check the availability of the manual. They may send it to your email if found available.
https://www.2instructions.com/search.php?cmarque=ONE.TEL&modele=MAGMA%20200
Oct 12, 2008 | Lands Phones
How do volcanoes erupt
Very simply: There s a layer of melted rock, called magma, below the Earth\'s surface. That magma is under tremendous pressure from gasses created when the rock melts, from the growth of the rock when it melts, and from the melting of other rock around it. When the pressure on the magma gets high enough, some part of the "pipe" it\'s in - that is the Earth\'s surface - breaks and the magma bursts out. As it escapes it cools, forming a mound. That mound is a volcano.
Jun 20, 2014 | Computers & Internet
WE changed ISP from Magma to Bel but Magma still hangs onto the operating system,how can I get rid of Magma
The only thing you can do from that point is reformat the computer if it's such a big deal. When the computer is set completely, since it's in the OS already, you can't really remove it without registry edits which can be a complex task for individuals who aren't use to IT work.
Feb 23, 2013 | YouTube Videos
Magma grill to a 3lb propane tank
Propane burns at 14 wc so this could be a reg fault , yes it will freeze too much gas not good .
Mar 18, 2012 | Magma Grilling
Accessing Messages
is der any error msg if yes den send me
Aug 04, 2009 | Lands Phones
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
Phone
If you still have this phone I think I have the answer to your problem. Press the no. 9 key on your handset and then the no. 2 key - you should then hear your message. Good luck Jacx
Mar 28, 2008 | Lands Phones
Lands Phones Logo
394 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
