Question about Samsung HCN653W 65" Rear Projection Television
Convergence drift My HCN653W is about 2 years old. I find that the convergence drifts, so I bring up the crosses and reset the convergence, I save the settings and the picture looks perfect...for a couple hours. After a couple hours the convergence is off again--way off. It seems to happen in random spots on the screen, in varying degrees...but it's always significant. I've never had this problem before, it only just started.
  • 70 Answers
The feedback control is not working on one of the colours.
Check vblk and hblk pulses. and then check stk to convergnece module feedback pulse.
Posted on Dec 18, 2008
  • john clyde Dec 28, 2008
    Hi some samsung models are renowned for this problem.
    First off if the stk i.c.s are crook then this can happen.
    The most likly cause is the vblk and hblk pulses are not there on the convergence control
    module. The vertical ic can cause this usualy its marked la7845 .
    If all else fails then you will most likely have to replace the convergence controller.
  • 513 Answers
Well, problem is that your TV is just too big... ;] Most probably you're looking at a job that includes replacing some STK chip on the convergence board, or the board itself. in parts a chip should be around 5 bucks, and the board over a hundred. Good luck
Posted on Jan 22, 2006
I have a PHILLIPS scrren HDTV MODEL #51PP9100D/37 and it hs green and red outline on picture. Can you tell me what could be wrong? Can this be fixed? Didn't know if it is something I can do myself or...
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help
www.youtube.com/watch?v=esk4nYZKFcg how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Mar 08, 2014 | Philips 60PP9202 60" Rear Projection...
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
HOW DO I BRING UP Convergence drift
need replace convergence ic chips to resolve this issue, parts cost about $40
Dec 18, 2010 | Samsung HCN653W 65" Rear Projection...
Tv is 10 years old, the red drifts to the right and some times reverts back to normal its a Mitsubishi 1080 55" Rear Projection WS-55809, I found this...
The Tvrepairkits.com to buy a convergence kit,will fix ur red color line or color shadow pictures drifts problems.But u must have tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders,also can u do basic soldering skills work,than u can fix this problems.Yes,the new tv design have Energy Star incorporated in it design and will save u energy and some money,but the power consuption of a big screen tv any century era,still will cost u alot of money to operate it.
Dec 04, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Cursor when using Logitech Trackball sometimes drifts up or down
I finally just was able to solve this problem! I saw somewhere that someone had made sure their primary mouse was selected under hardware, which got me thinking. I thought I had seen a second mouse option somewhere. So, I went into my Control Panel > System > Device Manager and click the arrow next to Mice and other pointing devices. Sure enough, there were two listed. A seemingly generic one and my Logitech I've been using. I right clicked on the generic one and chose disable and the drifting IMMEDIATELY stopped. I went so far as to re-enable that generic to see if it was a fluke because it had stopped drifting on its own yesterday, nope as soon as I enabled the generic device, drifting started again. So Happy!!!
Jun 11, 2009 | Logitech Trackman Marble FX Trackball
Replaced convergence board, but can't adjust convergence
Bad chips or faulty soldering....
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 10, 2009 | Zenith R40W46 40" Rear Projection...
Sony KP-57WS500 convergence drift
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Nov 10, 2008 | Sony KP-57WS500 57" Rear Projection...
Green Tube Convergence Issue
Greetings abflex,
You definately came to the right place! Here is a link right here on FixYa with the directions on how to correct this problem.
http://www.fixya.com/support/p186391-jvc_av_48wp30_48_in_rear_projection/manual-17247/page-52
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Reverse fisheye!!
you are going to need to replace the convergence board assembly. It is available at http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP95%2D00142P&search%5Fmodel=HCN653W. Also get the service manual, as you will need to do some touchup convergence and reset the perfect focus setup again If you have the technical ability. If you do, great! If you do not, these service menu alighnments can mess up your set, so take no shortcuts. Good Luck
Mar 29, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
105 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
