Question about Linksys Wireless-G WRT54G Router
One question only do i have to close the power when the router when my computer is close thank you
  • 53 Answers
Hello, if there turn off button on it you have to, but it is directly connected AC without any turn on/off buttons you needn`t. Turn it off when you go away for a long time.
Posted on Sep 07, 2008
Netgear WNDR4500 power light flashes, no internet access
most routers have a reset button on the side that you can access with a pin or small wire ,to reset you press in on the small button,if not you can always unplug your router and close down your computer then replug the router and restart the computer. normally this will solve the problem as the settings for the router are in the computer.
Nov 21, 2011 | Computers & Internet
How can I set up Dlink DIR 601 if idon't get to access http://198.162.0.1?
Try 192.168.1.1
This should be the proper address to talk to your router. Use a network cable to connect to the router and set it up using this address then you should be able to change the settings. I hope this helps and thank you.
Jan 11, 2011 | D-Link (R) DIR601 WirelessN 150 Router
Need security code for new laptop
I think we were disconnected with the chat session. Well, here is what you do, after you have reset the router, try connecting the laptop again to the network. It should not ask for a password this time. Please let me know. If this solved the problem, please do not forget to click the End Session button to properly close the chat and to accept the solution I provided. Thank you for using FixYa.
Virtualhost
Jun 30, 2010 | Arris Wireless G Broadband Router (wr850g)
I KEEP LOSING CONNECTION FROM MY BELKIN ROUTER. EVERY SO OFTEN I LOSE AND IT KEEP SAYING "NETWORK DIAGNOSTICS PINGED THE REMOTE BUT DID NOT RECEIVE A RESPONSE.
is that a wireless connection ? Does it happen with the wired connection as well ?
If its wireless, can you chk if you have any static devices close by that are bothering the signal .Also, make sure you have the router as close as you can to the computer If you are having a wired connection, suggest you try with a different cable
Thanks
Ranjit
Oct 30, 2009 | Belkin (F5D8231-4) Wireless Router...
Dose this router work as a firewall switch?
It is not possible to close all the ports on the router.
you can open other ports.
by default port 80 is open on the router.
On the router there is no such setting to close the port.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Same problem, can't close program that doesn't show it's running!
When you press the CTRL+ Dek key, the task manager would come up, Click on the processes tab. Select Outlook.exe or windows mail.exe in the list and select end proccess.
If the same doesnot work,try restarting your computer and then configure the router once again.
Thanks
Proton
Oct 17, 2008 | Linksys Wireless-G WRT54G Router
Internet keeps disconnecting
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 28, 2008 | Zyxel Prestige 660HW Wireless Router...
Router
hello!
parkervision tech support number: 800 532 8034
Step 6: Power on the computer on and configure the router settings if needed
May 08, 2008 | ParkerVision SIGNALMAX WR1500...
Configuring DLink Wifi router for Reliance broadband
quick questions
1. how did you setup your modem?..is it via PPPoA or PPPoE
2. can you please provide the model number of your modem
thanks
Apr 24, 2008 | Linksys Wireless-G Broadband Router
Router disappeared as an option on my computer
if all the light are on then the router is working, any flashing other than the wireless then refer to the manual.
Go to control panel>network connections, right click, then properties, then click the TCP/IP line, properties again and ensure that 'obtain ip address automatically' is ticked, click ok,  then close down the window, right click on the network icon again and then properties, then view wireless connections.
Any that appear in this list including your own if it shows need to be deleted, then when you close the window a pop up should appear in the task bar saying wireless networks detected, click the bubble then highlight your connection, click connect and if security is turned on you will be prompted to enter the passkey.
Type 192.168.1.1 in your web browser enter your username and password, then in the routers settings ensure that DHCP is enabled to allocate ip addresses automatically, then reboot the router if neccasary.
Oct 21, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
18 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
