Question about Samsung HLN567W 56" Rear Projection HDTV
  • 763 Answers
Sir did you check your manual for the configuration of it? or see your settings to your remote control. hope that helps!
Posted on Sep 07, 2008
Still dont have an anser for the traction control ligh@anti brake system if i have to take it in to have it looked at will be a 100. bill want to fix it my self
first thing to check is the sensor wires, should have one on each wheel. location is behind the drum or rotors unplug and clean them off check wire for cracks or breaks in them if those are ok then will need to replace the sensor (note:thay are listed as wheel speed sensor) and is somewhat of a task to replace. requires removing the hub unit to do so)
Aug 27, 2012 | 1998 Oldsmobile LSS
Color wheel flashes multiple colors after operating fine for about 7 minutes. Shuts down on it's own and temp/power light blink amber. No heat exhausting from fan. Problem persists.
You have to check the color wheel of your projector. Every dlp projector have color wheels to provide color. if the rotation of the color wheel is not in corrct RPM this will happen. Also you have to check the color wheel RPM counter sensor. There will be a sensor near the color wheel To count the rotation of the color wheel. First of all you have to remove these two items carefully and clean it well.Then refix it and check. Added the picture of color wheel for your refference.
Jul 27, 2011 | Dell 1409X DLP Projector
Ansering systemis "OFF" and will
What model Uniden cordless system?
Jul 12, 2011 | Uniden Cordless Phone
The picture works but there is a loud roaring noise when you tourn set on
The tv have a colors wheel design into it.The tv colors wheel is dying and spinning off it motor axis.The noises u are hearing are the colors wheel is grinding and hitting it steel hall of it frame box.U have no mechanical skills don't tries to replaced the colors wheel by ur self,because the colors wheel sit way back of many mechanical parts of the tv must take out before even can come to the colors wheel itself to replaced the colors wheel itself.Hire a tv tech to do the job to change the tv colors wheel.If u have no mechanical skills to take out and putting it back of tv colors wheel itself,because u will regret it,if u do it ur self and putting in the colors wheel in the wrong way to the tv itself.
Apr 14, 2011 | Samsung HLN5065W 50" Rear Projection...
My uniden phone rings and goes to answering machine in 2 rings
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Activating the ansering system
You do it through the handset in Program mode.
Apr 05, 2009 | Sony SPP-S2730S Phone
Pink and green with double writing
Are you able to do a multipoint convergence adjustment in the convergence menu? Do the red and blue adjustments move in all four directions/ Let me know and I will try to assist you.If the anser is no to either problem you will need new convergence ICs and convergence resistors.
Jan 08, 2009 | Philips 60P8341 60" Rear Projection...
The 'anser' is no. LG model numbers for DVD writers that support Lightscribe end with an "L"; e.g. GSA-H42L.
Jul 24, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Color cartridge won't print/ black and white is fine
Hi Franelyn !!
giving u some steps so that you get anser to ur question that why your color ink cartrideg is not workign
It might be beacuse of faulty printheads of printer or fauly printheads of cartridge
To check which one is faulty : take a tissue or cloth ...slightly moistened it with water an dtry to clean nozzles of cartridg and observe that some ink is coming out from cartridge or not , if not shake the cartrideg again clean its nozzles , if still no ink comes out that will ensure that the cartride is bad
Nov 29, 2007 | Lexmark X1270 All-In-One InkJet Printer
Samsung HLN567W 56" Rear Projection HDTV Logo
Jerry Greenberg
Jerry Greenberg
